My laptop keeps crashing
11
I have dell laptop 1525 which run on Windows Vista Home Premium.
Lately, It started to shut down while watching online streaming or while using Skype.
Please help
Yard Dog
2,169
Location
Central Florida in a small town
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
11
system report file attached.
Is Vista . . . - x86 (32-bit) or x64 ? 32bit - the original installed OS on the system? yes - an OEM or full retail version? OEM - OEM = came pre-installed on system - Full Retail = you purchased it from retailer - What is the age of system (hardware)? 4years - What is the age of OS installation (have you re-installed the OS?) yes
richc46
Staff member
20,105
Location
Fairfield County, CT
Dump reports rarely give a definitive answer, but usually give small clues that point the way. Yours seems to indicate a memory problem. Please check memory and report back. Make at least 6 passes and then take a good stick and test each slot, for 6 passes.
Guide to using Memtest86+ - Geeks to Go Forums
