Need help deleting Java 6 Update 29
29
Now before I am told to use search feature or the usual fixes please do not unless there was an exact same issue found and solved and I couldn't find. but please read first. So I have used JavaRa, Revo Uninstaller, Deleted Java Registry from tutorial on the Java site and it i still in the add/remove programs list with no option to uninstall. When I do a Java test on the Java site, it says I do not have Java. However, when I try to install the new version of Java (31) it gives me the same error; stating it cannot find jre1.6.0_18-c-l.msi I also downloaded Update 29 on my other computer and searched for the file in the location, the installer was looking in. It was not there and yet it still uninstalled properly. I have installed Update 18 looking for that file as well. In both updates 18 and 29 while I installed I looked in %temp% and copied the installer changed the name to the file needed, and placed in the correct file path, that didn't work either. I have completely ran out of ideas of how to fix this issue. Is there anything I can do without taking a bat to my pc or wiping it?
Thanks.
richc46
Staff member
20,105
Location
Fairfield County, CT
Yard Dog
2,169
Location
Central Florida in a small town
Hello.try using Ccleaner. clean out temp files and cookies.. then reboot and see how you do .
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
Hello garyjones93 and welcome to the forums :party:
Can you post the JavaRA log for us please?
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
Lottiemansion
1,948
Location
Sheffield
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
29
#8
Tom
It says it deletes it, but never really does.
Code:
JavaRa 1.16 Removal Log.
Report follows after line.
The JavaRa removal process was started on Tue Mar 20 16:39:52 2012
Found and removed: C:\Users\Gary\AppData\LocalLow\Sun\Java\jre1.6.0_18
Found and removed: C:\Users\Gary\AppData\LocalLow\Sun\Java\jre1.6.0_20
Found and removed: C:\Users\Gary\AppData\LocalLow\Sun\Java\jre1.6.0_21
Found and removed: C:\Users\Gary\AppData\LocalLow\Sun\Java\jre1.6.0_25
Found and removed: C:\Users\Gary\AppData\LocalLow\Sun\Java\jre1.6.0_29
Found and removed: Applications\java.exe
Found and removed: Applications\javaw.exe
Found and removed: JavaPlugin.FamilyVersionSupport
Found and removed: CLSID\{CAFEEFAC-0013-0000-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0000-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0000-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0026-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0027-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0028-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0029-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0013-0001-0030-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0020-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0020-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0021-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0021-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0022-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0022-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0023-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0023-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0024-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0024-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0025-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0025-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0026-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0026-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0027-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0027-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0028-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0028-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0029-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0029-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0030-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0014-0002-0030-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0014-0002-FFFF-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0023-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0023-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0023-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0024-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0024-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0024-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0025-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0025-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0025-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0026-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0026-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0026-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0027-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0027-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0027-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0028-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0028-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0028-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0029-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0029-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0029-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0030-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0030-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0015-0000-0030-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0011-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBC}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBB}
Found and removed: CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBC}
Found and removed: JavaWebStart.isInstalled.1.6.0.0
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0015-0000-FFFF-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{CAFEEFAC-0016-0000-FFFF-ABCDEFFEDCBA}
Found and removed: Software\Classes\CLSID\{E19F9331-3110-11D4-991C-005004D3B3DB}
Found and removed: Software\JavaSoft\Java Update
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0008-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0009-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0010-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0011-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0012-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0013-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0014-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0015-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0016-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0017-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0018-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0019-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0020-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0021-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0022-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0023-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0024-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0013-0001-0025-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0000-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0001-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0008-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0009-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0010-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0011-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0012-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0013-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0014-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0015-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0016-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0017-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0018-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0014-0002-0019-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0008-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0009-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0011-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0012-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0013-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0014-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0015-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0016-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0017-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0018-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0019-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0020-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0021-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0015-0000-0022-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0000-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0004-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0005-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0006-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0008-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0009-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0014-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0016-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0019-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0020-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0021-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0022-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0023-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBB}
Found and removed: SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0024-ABCDEFFEDCBC}
Found and removed: SOFTWARE\Classes\JavaPlugin
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.6
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1_02
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1_03
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.0.1_04
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.2
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.2.0_01
Found and removed: SOFTWARE\Microsoft\Active Setup\Installed Components\{08B0E5C0-4FCB-11CF-AAA5-00401C608500}
Found and removed: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4A03706F-666A-4037-7777-5F2748764D10}
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.1.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.1.2
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.1.3
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.2
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.2.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.3
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.3.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.4
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.4.1
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.4.2
Found and removed: SOFTWARE\MozillaPlugins\@java.com/JavaPlugin\MimeTypes\application/x-java-applet;version=1.5
The JavaRa removal process was started on Tue Mar 20 16:40:08 2012
Found and removed: C:\Users\Gary\AppData\LocalLow\Sun\Java\jre1.6.0_21_x64
Found and removed: C:\Users\Gary\AppData\LocalLow\Sun\Java\jre1.6.0_25_x64
Finished reporting.
The JavaRa removal process was started on Tue Mar 20 16:46:50 2012
Finished reporting.
The JavaRa removal process was started on Tue Mar 20 17:15:05 2012
Finished reporting.
The JavaRa removal process was started on Tue Mar 20 20:49:36 2012
Finished reporting.
The JavaRa removal process was started on Wed Mar 21 21:49:48 2012
Found and removed: SOFTWARE\Classes\JavaPlugin.160_18
Found and removed: SOFTWARE\JavaSoft\Java Plug-in\1.6.0_18
Found and removed: SOFTWARE\JavaSoft\Java Runtime Environment\1.6.0_18
Found and removed: SOFTWARE\JavaSoft\Java Web Start\1.6.0_18
Found and removed: SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0018-ABCDEFFEDCBA}
Finished reporting.
The JavaRa removal process was started on Thu Mar 22 18:17:08 2012
Finished reporting.
The JavaRa removal process was started on Thu Mar 22 18:22:27 2012
Finished reporting.
The JavaRa removal process was started on Thu Mar 22 18:34:37 2012
Finished reporting.
The JavaRa removal process was started on Thu Mar 22 18:51:23 2012
Finished reporting.
The JavaRa removal process was started on Thu Mar 22 21:06:17 2012
Finished reporting.
The JavaRa removal process was started on Fri Mar 23 19:27:14 2012
Finished reporting.
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
#9
So are those files and registry keys still there?
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Yard Dog
2,169
Location
#13
Did that succeed ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
29
#14
No, it did not, that is why I posted this thread. So far nothing I have been told I have not tried before this thread. Well it is gone from Revo and Program Files but not add/remove programs.
Yard Dog
2,169
Location
#15
quite strange. indeed.. i have never had Revo Uninstaller not work.. i would assume you used the Advanced Removal part of that program.. Download | The PC Decrapifier free.. check this one out..
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yard Dog
2,169
Location
#17
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
richc46
Staff member
20,105
Location
#18
It appears to me that some remnanats of Java remain, which cannot be deleted using normal means. I think that the best course of action is:
Download Temporary File Cleaner and give it a try
It is more powerful than Ccleaner, but your cookies will be deleted; they will return when you revisit the affected sites
TFC - Temp File Cleaner by OldTimer - Geeks to Go Forums
If that does not work, try to reinstall, then if you can, delete the entire thing with revo.
richc46
Staff member
20,105
Location
#20
Try to delete it with TFC as suggested. I have seen that software do miracles.
