Need help retrieving deleted folder and files (windows 10)
neil30
Hi all and thanks in advance to any help that can be provided.
For some reason unknown to me, i used disk cleanup last night to clean my disk and like an idiot, i chose to include my downloads folder which held several files an folders
including a folder which had around 1500 mp3 tracks.
the path is the following c:\users\MYNAME\downloads\
I have used Recuva in both wizard and advanced mode which was only a small help and i recovered only a few files but not the folder which contained my 1500 mp3 tracks.
The path for this was c:\users\MYNAME\downloads\to hd
I had pinned the folder to quick access and it is still there but just gives a message saying its unavailable, may have been moved or deleted etc.
There are no previous versions of the folder i can restore too and have used system restore to go back in time which hasn't helped.
Can anyone shed some light on how i can retrieve these lost files and folders or are they gone forever?
    No manufacturer- built pc.
    2.30 gigahertz AMD Phenom 9650 Quad-Core
    ASRock ALiveNF6G-GLAN
    4.00 GB
    NVIDIA GEFORCE 9400 GT
    High Definition Audio Device / NVIDIA Virtual Audio Device
    Hanns.G Hi221 [Monitor] (22.0"vis, s/n 902RH3XY01826, January 2009)
    1680 x 1050
    MAXTOR S TM3250310AS SCSI Disk Device (250.06 GB)
    Microsoft USB Dual Receiver Wireless Mouse (Mouse and Keyboa
    Optiarc DVD RW AD-5200A ATA Device [Optical drive]HP HP Deskjet F4200 series (DOT4USB)
wither 3
Did you empty the Recycle Bin when you ran the cleanup? If not, you could look there. Surprised that Recuva couldn't find them. There's another piece of software called "Recover my Files" that might help.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
neil30
Hi, yes as it was ticked to clean up during the disk clean up process so the recycle bin was cleaned too.
Recuva found the majority of the files in my download folder all apart from my mp3 tracks in the sub folder called to hd above.
It also strangely found 1 folder of an artist but there were 3 other folders of other artists it didn't find.
    4.00 GB
    1680 x 1050
wither 3
I don't save any personal files on the C:. I have all my software set to save files on another partition. I also back them up daily to another drive.
I'm still surprised it can't find them because all I think Disk Cleanup does is reset a bit on the sectors/cluster. There's software out there for doing deep recoveries but it's not cheap. Of course, those reset clusters/sectors are going to be overwritten eventually so it's necessary to do the searches immediately.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
townsbg
~~тσωηsвg~~
File recovery can be expensive and isn't guaranteed. There is software but like wither said it can get pricey. If you can't live without those files you can buy the software or hire a company that specializes in data recovery but it isn't guaranteed. If rescuva can't find the files I wouldn't put much hope in finding them.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Ex_Brit
If you're going through hell, keep going
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    1 external eSATA LaCie 3TB
    (Non-RAID)
    Unique
    1gb/s up and down
wither 3
Okay Ex_Brit, what does that mean?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Ex_Brit
What does what mean? FYI?.... it means for your information.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
wither 3
I know but, for me, all it does is take me to the Ten forum and no specific thread. Just trying to figure out which information you're alluding to.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Ex_Brit
Your header states Windows 10 so I was merely pointing out where that forum is.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    2 x 500gb SATA II
    1 x 1TB SATA II
    (Non-RAID)
    Unique
    1gb/s up and down
wither 3
Ah, good catch.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
townsbg
~~тσωηsвg~~
He's suggesting that the OP go there.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
