New Build Fresh Install 7E Crash Mem Dumps
leviathanrising
As in title.
I've just built a new system with spec:
Phenom II 3.4Ghz (x4)
8Gb Patriot DDR3-1333Mhz
Gigabyte Motherboard
MSI graphics-1Ghz GPU
Seagate 500Gb Sata HD
DVD-RW Sata
On loading Vista x64bit (fresh install) to the point where it is preparing to load up for the first time I'm suffering from a recurring BSOD where there is a 0x0000007E error memory crash dump, and continues to do this on start up.
I've run memtest, all memory is fine.
Any pointers appreciated.
    Own build
    Phenom II 3.4GHz (x4)
    Gigabyte
    8Gb Patriot (2x 4Gb)
    MSI
leviathanrising
richc46:
I appreciate the rules for showing dump files, but I havent even had the opportunity to get past start up yet to retrieve them.
    Own build
    Gigabyte
    MSI
richc46
Tell me if it boot in safe mode
leviathanrising
it tries to, it loads up the critical files for start up but still crashes again with the same mem dump error.
    Own build
    Gigabyte
    MSI
richc46
They are not memory dumps. I make this mention only because areas other than memory can be the cause of the problem. If you built the system you will know how to check for these causes of the crash
7E
Usual causes: Insufficient disk space, Device driver, Video card, BIOS, Breakpoint with no debugger attached, Hardware incompatibility, Faulty system service, Memory, 3rd party remote control,
townsbg
~~тσωηsвg~~
When booting in safe mode what is the last driver listed?
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
ilikefree
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
leviathanrising
In safe mode it hangs on crcdisk.exe before crashing again, i've removed the gpu card, working on on board graphics, no change.
    Own build
    Gigabyte
    MSI
townsbg
~~тσωηsвg~~
crcdisk.exe or sys? See this.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
