No Audio output device installed
HP9925nr
Hi
i have a problem like many of you here which up till now i cannot solve. I have an HP Pavilion dv9925nr laptop and I uninstalled the sound driver due to some sound trouble while playing a game, but unfortunately after trying to install its driver back again vista didn't detect my sound card which I guess it's an on board card. I have tried different drivers and I even restored my laptop to it factory setting but to no avial. Any suggestion would be greatly appreciated.
How did you Uninstall Your Sound Card also what Model is your Sound card?
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
I uninstalled it from the device manager. I'm not sure about my sound card but it's just standard , how can I find out what's my sound card ?
    AMD HD Radeon 6870
    Novatech Night
Well You could do a Clean Boot but this is very Long Process do you have the time?
    AMD HD Radeon 6870
    Novatech Night
    AMD HD Radeon 6870
    Novatech Night
It all Depends on How many programs you have Installed
    AMD HD Radeon 6870
    Novatech Night
What version of Bios do you have?
I think you will need to reset the sound card in the bios!
Can you access the bios & in the sound card in the settings "Force active" or de-activate on one boot & then re-active it on next boot?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
I tried following the procuder but still no sound after the first restart, should I keep folliwing the rest of the procedures ?
I would stop the Proceedure now if it didn't work
    AMD HD Radeon 6870
    Novatech Night
Well,
Flashing the Bios might be a way of resetting it?
    40 Meg
You can load the bios from windows or Dos, this is dependant on the method, and this could reset the bios to re-enable the divice if it is just locked up.
Your Bios/ drivers etc are available on the HP website, but I would like to confirm the version before attempting any modifications! So, please post your version. OK
    40 Meg
