No sound from TV with HDMI cable
Zerow
New n mad i am. like the topic say's up top. i'm having a hard time getting this Sony [yes i know. sony n microsoft don't mix >.> but...] HDMI cable to work. first i plug both ends in. a windows comes up asking to setup display. i put n mirror. propblem. at first this was cool. everything work. but when i played Combat arms i said wait. no sound??? i tried everything from my T.v settings to my laptop. nothing seems to work. i tried going to sound and and set HDMI as default but that only get me no sound from laptop nor tv. I just want sound from my tv. not laptop, not both. i also seen a topic here about this but that didn't seem to help. what i got is this...
Sony high speed hdmi audio/video cable
idea 4 hdtv,ps3,dvd.blue ray,hd cable n satellite box
don't know what my tv is but its got 2 hdmi port 4 hd inputs a game mode n it's an dvd player.
now 4 my laptop.
AMD turion X2 RM-72 Dualcorl mobile process
windows home vista home premium 64bit service pack 1
4096MB DDR2 system memory
250GB(5400rpm)
webcam
ati radeon HD3200 graphics
theirs more but i think that all u really need i guess
HP Pavilion
Entertainment Notebook PC please help:cry:
now 4 my laptop.
250GB(5400rpm)
webcam
HP Pavilion
I had the same problem and I have a HP laptop, but I found out that you have to make sure you are getting a good connection.
Zerow
good connecting? what kind? internet? guess it don't matter. i'm taking this over price thing back anyway. but i would still like help. i should b able to plug in. switch my audio n done. nnnnnnooooooooooooooooo. we have to do it the hard way
T.T first i get the ring of death now I can't get the audio to work. how much more must i go thought y microsoft y T.T
good connection between the laptop and the tv.
When you buy cables in a store, look at them first. If they are in a clear plastic package, look at the bends of the cable. If the cable looks like the bends may have been forced to bend sharply, the wires inside the cable could be damaged. Don't buy that one.
Look for cables with bends that don't look they are forced into a small package.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
Zerow
nope. nothing is wrong with my cables. ha lol i look in my xbox 360 box and found another pair of HDMI cables O.o even with these I still can't find the problem. for most people they say. go to sound my put HDMI as default. reset my music player in everything should work but it don't. i can get it to play out my laptop or laptop headphone set but like i said b4 I want sound coming out of my tv for better sound.
Zerow
just wondering if any 1 was going to get me a help n hand on this problem? yes no maybe? after messing with this i have found some thing out. 1. it seem that i have done and have everything hook up right. yet i still get no sound from tv? i even try downloading other type of hdmi audio which fails to work >.> so far i have 1 end to my laptop in the other to my tv. plus i also when 2 sound n change my sound from laptop speakers to hdmi output which should be my tv speakers. i when 2 other forums in this was the answer to their problem. i also have met 2 other people who has the same problem as be but their was not more post after it so like...now what?:sarc:
Silly question time... does the sound on the tv work otherwise ?
When you just watch tv programs ? Play a dvd or video tape using the apppropriate player cabled to the tv ?
Check the hdmi input connector, not the cable, on the tv, are any of the pins loose ?
    Acer Aspire X1700
    ASUS
    3 gigs
    Vizio 21" tv
    basic USB
    basic USB
panais
Power User
#8
Start/control panel/sound-set hdmi as default device.
Tip a)The hdmi sound is on the minimum level by default,so remember to select hdmi properties/levels,and increase the volume to maximum.
Tip b)Increase also the tv volume cause the sound from hdmi usually is a bit weak.
Try also to set your tv as the primary screen before do all the above.
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM
    D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter
    KINGSTON HYPER X FAN
    +Cordless Rumblepad 2
Zerow
yes my tv does work with normal cable n dvd. n panais I tried all that but nothing works. maybe their is something i can download or upgrade or even go deep in my files to find the problem.
so i still...>.> can't get this to work. so far i tried 3 differrent HDMI cables. i put HDMI as default but still no sound. i max my volume on tv n laptop. still not sound. yes my sound works on both tv and laptop alone. yes my laptop is able to play audio with HDMI but i still can't get to work plus tv n laptop manual are not helping one bit.
N i DARE u to say I forgot a simple step.
:mad::(:cry::sa:
ok if you want to do this the cheap arse way get a 3.5mm jack (headphone) to mono/stereo and plug it into your TV you will have sound, TV sound wont be Hi def anyway, it will only be stereo, so this is the same quality... kinda
    Core2Quad Q9550 @ 2.83Ghz O.C'd to 3.86Ghz
    XFX Nvidia 790i Ultra SLI
    4x2GB Corsair DDR3@ 1333Mhz
    Asus Nvidia GTX 280
    Creative PCI Express X-Fi Titanium Fatal1ty Pro Series
    Benq 24in 1920x1080, Viewsonic 22in 1680x1050
    1920x1200 + 1680x1050
    Samsungx2 750GB SATA II 32MB SATA Hard Drive RAID 0 array
    Antec 850Watt
    Cooler Master Cosmo S 1100 Extended ATX No PSU Aluminium Blk
    7x 120mm Fans
    Logitech G7, Logitech G9
    Logitech Dinovo Edge, Logitech Dinovo Mini
    24Mbit p/s
