Solved No sound
Brit
Recently, when I open an email in my WinMail and find a link to U Tube (for example), I cannot get any sound with it. Can you tell me in terms that I can understand what I should do. Thank you for any help.
Yard Dog
Can you get sound from a regular YouTube link ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    Acer E181H ([email protected]) 128MB GeForce 6150SE nForce 430 (
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Yard Dog
Go to Start button, then Search, type Audio Manager and see if it finds your Audio Manager, if so, open that up, then look in Sound Manager and check settings for default or enabled and see if you can get the sound test to work , check volume levels also.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yard Dog
Are you saying that it did not open up and give you any thing to manage as far as Audio devices, Sound Manager , Volume Control, you got nothing ? Can you provide some details please ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Brit
It took me to the Realtek HD Audio Manager which had info on it for Speaker Configuration, Sound Effects, Room Correction, and Default Format (which is 24 fits, 48000 Hz (Studio Quality). Two other options are CD Format and DVD Format. Also Adjustment for Volume. That's it.
Yard Dog
So, do you have Stereo selected for Speaker config, what happens when you press the Blue Arrow , that if you mouse it says Auto Test ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Brit
Speaker Config has drop down menu that shows 2 2.1, 4 3.1, 5 5.1 speakers. When I click on blue arrow it just makes the speaker pictures blink. No sound.
Yard Dog, I am sorry, but I need to sign off for now. Can we take this thread up again tomorrow?
Brit
Sorry, I got lost and forgot to get back on this forum. I have looked at the Audio Manager again and either I am not understanding anything I read, or I'm just dumb. When I try to get a sound, the speakers just blink without sound. Question: Does running a video have anything to do with Java? (I think I have lost my Java program.
Yard Dog
Update your Java.. adobe Flash.. and new ccleaner.. and if you use Sandboxie.. all new stuff..
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yard Dog
well.. i don't think it is solved yet.. just pointing out .. new java stuff and etc.. you should get.. if you use them..
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
