no sound
ksd
I have a Dell desktop operating Vista 32bit with Realtek speakers. They are not working. I have checked everything, they are plugged in, have a green light on them, they are plugged into the back of the computer. I have uninstalled and reinstalled the driver, restored the computer to a point when I thought they were working. I have two icons on the lower right corner. One white speaker with a red x and an orange realtek icon. THe realtek shows that I have no audio device installed when I open the volume control. The other icon shows my speakers working properly, that is a green check mark next to them. However when I open the properties the levels tab is blank.
Any help is greatly appreciated.
If you go to Control Panel\Sound, are the speakers checkmarked? Is Realtek HD checkmarked?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Are you able to access the Realtek setup program from there? I'm not on my Vista machine right now so I'm going by memory. I''ll get details tomorrow.
Also in Control Panel, Device Manager, Sound....., are any errors listed.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
In Control Panel\Sound, if Speakers\Realtek High Definition Audio is shown and checkmarked, click on it and select Configure. You should be able to set the proper configuration and test it. I find the software to be strange because I can usually get to the full Realtek setup from there but only get part of it.
In addition, do your speakers have manual controls on each. If so, are they turned up.
Do you have a manual switch to turn them on and off?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
When I click the configure botton nothing happens. Same with the test button under properties. The speakers do have a manual button, they are turned on and up.
What model Dell is it? Dell is one of those manufacturers, like Sony and others, whereby only drivers sourced through their website actually work, even if they are for hardware that you would normally get the drivers from the actual manufacturer, such as NVidia or Realtek. This is because they take the basic driver and tweak it (add/remove features) so that it works correctly with their implementation of the hardware.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
I unistalled the driver and reinstalled it from the Dell website. Nothing changed. When I right click the speaker icon on the bottom toolbar which has a red x on it, if I open the volume mixer it says no audio device installed. Yet when I right click and open sounds it shows the speakers with a green check under playback tab.
    Gigabyte IF233
I just reread your original post. Click on the white speaker with the red x. On the bottom of the resulting screen, you will see a speaker with a red x on it. click on that. The red x should disappear and you should have sound.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
No Sound for me either. When I run a test on 2-High Definition Audio device (it is checked in green) the meter is bouncing but no sound???? I uninstalled one of the two realtek programs - well, now I don't see anything realtek, I may have uninstalled the other. Do you have the link to re-install realtek??
This seems to be a BIG problem - The Geek Squad dude said I probably needed a new sound card. I am thinking it is something you Smart People can fix?????????????????
Gateway
Model - GT5676
Processor - AMD Phenom, 9600 Quad-Core processor 2.30 ghz
Memory - (RAM) 4.00 GB
System Type - 64-Bit
Did you get a CD with the mobo drivers with your system? If so, it should be on there. That would be for the onboard sound chipset.
Do you have a discrete sound card?
This is where the Realtek drivers are- http://www.realtek.com.tw/
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
No disk - I think they did everything at BestBuy. Discrete sound card??? Thanks for the link, but what do I download? This is not my area of expertise.
A discrete card is one that you have to install on the motherboard. Most motherboards come with integrated audio chipsets.
I would install v6.250. The only problem i have is that the site lists US1, US2, and US3 and I don't know what that means. I didn't try to find out at the website.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Where to go? What to download? How to fix?? You never really think about but, NO Sound is a real pain!!!!!!
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My computer is Stock so, No Discrete Card. My speaker systems is 5 Creative speakers, 4 are 4"x4" and one is a base/junction box 8"x8" The patch cord (2 plugs, Green/Black) run from the base/junction box to the computer. The 4 little speakers plug into the base/junction box as well as a control (on/off) volume dial. When you turn the dial on the light still comes on, power is running through the system. When a CD or a video is played all the audio meters bounce as if I am hearing it BUT - No sound! No Hum? Nothing out of the speakers! Like they are all disconnected or all muted?? HELPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!
OK - In the last few weeks Microsoft has done 50 or so automatic updates on my computer! This has to be the problem!!!!!!!!! So????????????? I assume I need some of them? What to uninstall?
