No wireless signal
My Viao connects to the internet with LAN but it doesn't detect the WLAN. I have done different things and none seem to work. I have also done some trouble shooting through Windows and the system says that the network adapter is not connected and need to be configured? Sony has some drivers and such that might help https://www.sony.com/electronics/support/articles/00006787 but they aren't for Vista only for Win7. I checked inside the laptop and the wifi card is properly seated and connected, the wireless light has never been lit. There's also continuity from the adapter all they to the antenna. I've also checked the drivers by going to the device manager and checking for updates under the network adapter and it says that the most current drivers are installed, i've also uninstalled the network adapter driver and installed them back. It's funny because i see the ROKU under the network screen... I'm thinking the WIFI switch might be faulty but that wouldn't make sense since it detects ROKU?
    Win10
    Toshiba C55-B5256
    • Intel® Core™ i5-4210U Processor @ 1.70 GHz.
    ^3M Cache, up to 2.70GHz with Intel® Turbo Boost Technology
    8 GB DDR3
To be more clear Sony offers these two drivers to work with internet but are these mandatory as in- if you can't download those drivers you're screwed? This is what i copied from their site which is provided in the link on top
""Turn on the WLAN adapter with one of the following:
Please help.
    Win10
    Toshiba C55-B5256
    8 GB DDR3
What do you mean by you see roku? Can you take a screenshot of device manager at the networking devices? Also one of the network center. Can you also from command line run the command ipconfig /all and then post the results?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Here are the screenshots which i had to take with my phone because Print Screen doesn't work along with brightness adjustment through the keyboard but that's a topic for another day. Btw, the roku only comes up in the network screen when the LAN cable is plugged in.
    Win10
    Toshiba C55-B5256
    8 GB DDR3
Windows isn't recognizing the device. It isn't showing up under ipconfig or device manager. To answer your previous question, yes you have to have manufacturer drivers for wireless devices. Those drivers aren't built into Vista or 7. I'm not so sure about 8.1 or 10.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
So, my only option is download those drivers from a third party but i'm concerned about downloading malware. Is there a site with a good reputation that you would say it's safe before i go and start messing everything i've done so far to make the laptop work?
    Win10
    Toshiba C55-B5256
    8 GB DDR3
I'll be posting a new thread under Drivers to not derail this one.
    Win10
    Toshiba C55-B5256
    8 GB DDR3
Preferably you would get it from the manufacturer's website. Outside of that I don't know which third party sites to trust. You can upload any installers into this site and have them scanned. VirusTotal If it doesn't find any malware than more than likely there isn't any.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
It seems this problem is solved as noted here-
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
