Utility Driver options for unsupported Viao Vista.
I need utility drivers for my Viao laptop that's running Vista. The utility drivers i need are for the wireless LAN connection; the laptop in question has a WiFi switch that won't work without drivers. Since Vista isn't supported anymore Sony doesn't have the drivers in their site so my only options are to either taking it to Best Buy according to Sony or just downloading them from random driver sites. My concern from third party downloads is the possibility of malware and such. Maybe someone has gone through this before and can advise me of a decent site to download these drivers from?
    Win10
    Toshiba C55-B5256
    • Intel® Core™ i5-4210U Processor @ 1.70 GHz.
    ^3M Cache, up to 2.70GHz with Intel® Turbo Boost Technology
    8 GB DDR3
wither 3
We gave you two possibilities in this thread-
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
OMG! The excitement is real. After downloading a few drivers from different websites to no avail i downloaded one from Snappy Driver and i don't know if it was that one driver or a combination with the ones before but i finally got a WIRELESS SIGNAL!! WOHOO! Hopefully i'm not celebrating too early, since bad things have happened before when everything seemed fined with this laptop. This wasn't even the driver from Sony that i was refering to on the 1st comment...but at least it's working. PHEW. Man, this has been an insane first trial for me. Thanks all for the help. I'm sure this laptop would keep giving me nightmares one way or another.
    Win10
    Toshiba C55-B5256
    8 GB DDR3
wither 3
What you should do is immediately set a system restore point.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
I did. Does Vista offer an option to make an installation CD/HDD with what i have at this point? So if the matter hits the fan then all i have is to connect that drive/cd and no more pain after that. Please excuse me if i sound overly ignorant right now.
    Win10
    Toshiba C55-B5256
    8 GB DDR3
wither 3
I recommend that you use something like the free Macrium Reflect to periodically image your C: drive. When you create the first image, create a boot disc from it that's used to restore the image.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Can i just clone the HDD? Wouldn't be better than an image? If not do you think you can explain why or why not?
    Win10
    Toshiba C55-B5256
    8 GB DDR3
wither 3
You can do either one. I create an image of my C: drive. All my personal files are on a separate partition and I do a backup of those using other software. Rather than expressing my ignorance, perhaps this will help-
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Ok. Thanks much!! BTW, i've also installed the DR reader driver that i was missing, i believe that the thing i have left to fix is the the driver to make the FN key work with brightness adjust and touchpad lock. There's also this peculiar Intel icon that when open part of the text is distorted. I attached the picture for better reference. Any ideas on how to fix this distortion.
    Win10
    Toshiba C55-B5256
    8 GB DDR3
wither 3
Looks like your resolution is too low. Right click on the desktop and select Personalize. In the Display Settings, is the resolution set to the highest?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
It's already in the max setting. But the issue only happens there, in that little icon. I'm guessing it's a driver but i don't know how many drivers i've downloaded already. I wish there was a site that there was a site that actually had every driver out there so i wouldn't have to be site hopping looking for drivers.
    Win10
    Toshiba C55-B5256
    8 GB DDR3
wither 3
I based my answer on the general appearance of all the items in your screenshot. Looks like VGA. What is the resolution of your display as shown in the display settings?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
1280x800. The only drivers i have left are some where Win displays a message reading that the publisher could not be verified so out of the two options i get i chose not to installed them. Should i install them?
    Win10
    Toshiba C55-B5256
    8 GB DDR3
wither 3
That doesn't look like 1280x but I could be wrong. I just adjusted mine from 1920x down to 1280x and I'm surprised at the difference. Go back to Personalization. Click on Adjust Font Size. Change it to 120. Does that help?
I would install the other drivers. You can always roll them back or do a system restore (you indicated you had set a restore point).
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Ok, so i tried changing the color scheme in Appearance to Vista Basic and it worked. I had it on High Contrast Black since the battery would last a bit longer with darker colors but i didn't know it would have that effect on the icon in question. Thanks a lot for your suggestions regardless.
    Win10
    Toshiba C55-B5256
    8 GB DDR3
wither 3
I'm glad you figured it out.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
