Solved Notification icons issue in XP
Brink
Staff member
mvp
Hello t-4-2,
From looking at XP's Group Policy settings, it looks like only the Clock notification araicon is available to disable.
I tested the Volume icon option in XP, and it does not work. I'm assuming the others will not work in XP as well since there is not a Group Policy setting for them either.
You are able to hide them in XP, but you'll have the expanded arrow button just like in Vista and Windows 7 though.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
t-4-2
Banned
Thank you.
I never use an XP, so my next question may appear silly...
What to do for XP users who are missing the notification icons ( clock, volume, network ) from system tray ?
Is system restore the only way ?
Hey, why don't you compile an XP Tutorials section ? ( kidding )
t-4-2
Brink
Staff member
mvp
Other than to see if they were set to be hidden or not, I don't know since I really haven't used XP much either.
    Lumia 1520 phone
Brink
Staff member
mvp
You're welcome.
    Lumia 1520 phone
JimJoe
Some XP icons cannot be added into the systry.
For sound, check on the popup for operating the volume controls within control panel.
It probably has a click point to show the volume controls on the systray.
I don't remember the network icon ever showing in XP.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
For the Network Icon, go into Network Connections, right click on the connection you are using and click "Properties". Bottom of the window, check "Show icon in notification area when connected".
For the clock, right click on the taskbar and click Properties. Check "Show the Clock".
    Acer Aspire 5810TZ-4657
    Genuine Intel CPU U2700 @ 1.30GHZ
    ACPI x86-Based
    3.0 GB RAM
    Mobile Intel 4 Series Express
    Realtek/Intel High Definition Audio HDMI
    Intel(R) 4 Series Express
    1366X768
    WDC WD3200BEVT-22ZCt0 - 300 GB HDD
    Toshiba 593500-B 3.0 750 GB HDD
    Thermal Laminar Cooling Wall Jets
    Synaptics PS/2 Port TouchPad
    54/100 MBPS
