Solved PCI Simple Communications controller
Brink
Staff member
mvp
Hello ManyBeers,
This would be for your dial-up modem.
What is your brand and model of computer? I'll be happy to see if I can find the driver download link at your computer manufacturer's website. :)
Hello ManyBeers,
I realized this after I posted and I reinstalled the driver and the message has gone away for now. Thanks.
It is defiantly your modem. Check your device manager, you probably have a yellow question mark. All you have to do is find out what kind of modem you have and install the driver.
#8
:confused: I have the same problem with the YELLOW EXCLAMATION & NO driver for a " PCI Simple Communications Controller" and have Vista Ultimate x64 SP2 installed and getting bummed about this one. Can anyone help ?
