Peer Guardian (Unsigned driver Warning)
MrElectrifyer
Electrical Engineer
Please what steps can I take to solve this compatibility issue? I am having an issue with peer guarian on my new 64 bit Vista home premium system. I intalled the peer guardian 2 software but when I try to run it, I see a warning about an unsigned driver problem. PLEASE How can I install peerguardian on my new x64 Windows Vista OS and have it running as normal like on an XP system.
    HP Pavilion dv3510nr Entertainment Notebook PC
    Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz
    Inventec 1505
    4.00GB
    NVIDIA GeForce 9300M GS
    Generic PnP Monitor
    WDC WD3200BEVT-00ZCT0
    Alps Pointing-device
    Standard 101/102-Key or Microsoft Natural PS/2 Keyboard with
Airbot
64 bit doesn't allow you to use unsigned drivers. You have use the F8 key when you boot up and select where it says Allow Vista to use unsigned drivers. You have to do this every time you boot up though I believe.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
MrElectrifyer
Electrical Engineer
Now there is another problem, when I try running peerguardian, it shows that it is loading, but all it does is stop indicating that it is loading and peerguardian does not display, everything remain as they were before I clicked the icon. I tryed fixing this by running "Recover Peeguardian" but this did not work. The driver signature overide is working but the program is not opening, how can I fix this problem?
    Inventec 1505
    4.00GB
    Generic PnP Monitor
Joan Archer
Cross Stitch Queen
Reading this and your other post about this software would make me think that the best thing you can do is uninstall it and if you've bought it try to return it for a refund saying it will not work with your system.:(
    Windows 10 Home
    HP 8312 (Socket FP4)
    Generic PnP Monitor ([email protected]) 512MB ATI AMD Radeon R5
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
TheShadow
Retired PC Builder
Although I don't run it here on my own PC, in my Computer business I've had to install several PC's now with the 64 bit version of Vista.
Several of the programs I use on Vista 32 to tweak it, tune it and make it generally run better, won't even run on the 64 bit version. There is NOTHING I can do about it, except find a work-around or just move on.
I like to use the old DOS program Deltree.exe in a batch file to clean out junk files on the HD of XP and Vista 32......but Vista 64 flatly refuses to run it. Go figure!:mad:
So I've re-written the batch file, just for Vista 64 and changed the line:
deltree /y "C:\Windows\temp\*.*"
to:
Echo Y | del "%windir%\temp\*.*"
That's just one line in a batch file that has about 40 such lines.
One line for every folder where Windows likes to store its JUNK.
I run my VICleanup.bat program from a shortcut in the Startup folder,
for a little "FREE Maid Service", every time I boot up in Vista.
I also put the shortcut on my desktop for a little instant Cleanup whenever I want.
It's also a part of my weekly maintenance routine, along with "Disk Cleanup" and "Easy Cleaner 2".
Stop laughing!! It keeps my HD clean and free of all the crapola that windows likes to collect. I've been doing this since the Windows 98 days and it really keeps down the clutter.:D
Sorry for getting OFF TOPIC, but it was just something that seemed to need saying.
Again I apologize to the author of this thread, but maybe, just maybe someone somewhere will get some good out of it.
Wishing y'all a very good 2009!
Shadow :cool:
    AMD Athlon Dual Core 5200+
    MSI K9N Platinum
    4 gigs DDR2-800
    WinFast
    Integrated
    19" Envision LCD
    2 Maxtor 160 gig SATA2
    1 Seagate 200 gig SATA2
    Antec Earthwatts 650
    Pac Man
    13 fans
    MS-Digital
    Generic
    Cable-5 meg
    Homemade, under constant mod.
