please help with sp2...not installing and continually rebooting
portal
6
So yesterday I decided to update my computer. Well after I did that I keep getting "Service pack did not install..reverting changes..do not turn off your computer" and then it just keeps shutting down and restarting doing the same thing.
So I downloaded a windows vista recovery cd which gave me the choice of restoring the computer, repairing, or reinstalling. Which I did all of those and it will just sit there loading forever and does nothing.
Please Please Please can someone help me. This is beyond frustrating.
Any help is appreciated. :sa:
144
Location
Crystal Lake, Illinois
I had this same problem and have no clue on how I fixed it. Magically one day when booting up it just worked and my problem was solved. I know this doesn't necessarily help you, but I thought you would like to know there are people out there with the same problem.
Sean
    Intel Core 2 Quad Q6600
    Gigabyte GA-EP45-UD3P
    Corsair XMS2 Xtreme Performance 2x2GB DDR2
    GeForce 9800 GTX+
    19'' Samsung 1440 x 900 (2ms) SyncMaster Widescreen Flat Panel
    OCC Gamestream 600w
    Apevia X-Discovery
    Razer DeathAdder
    Razer Lycosa
    Comcast; Download: 21.08Mb/s | Upload: 4.27Mb/s
2,049
Sean
You had truly luck.
For anybody which don't have luck...If you really desperate try this:http://www.vistax64.com/windows-updates/255426-service-pack-2-upgrade-0cx0000032.html
But I'm not guarantee it will work...
brummyfan
Brummy
731
Location
Birmingham
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
portal
6
Thanks for all the replies..
So can I download the SP2 ISO file from my other computer and burn it to a disk and try and install it on the other computer? Will that work? I can't do anything with my other one.
And yes, I have tried system restore in safemode. The only problem with that is it said I had no restore points on my computer.
portal
6
#8
-reinstall OS
-if you desperate:try method which gave you in post 3
EDIT
If this only missing restore points :
Have you tried method three from this link? The update is not installed successfully, you receive a message, and the computer restarts when you try to install an update in Windows Vista
Ok, so I tried the 3 methods and none of them worked. I guess I'll try and burn this service pack 2 iso disc and install that.
I hope this works.
2,049
#10
Ok, so it didn't work...am I just going to have to trash this computer? :cry:
You can't install two times service pack!You have already initialized SP2 installation.Run system in safe mode,Open Control Panel>>Programs and Features>>Installed updates and make sure Service Pack 2 figured in the list.If I have right follow below:
Run cmd.exe and type
slmgr -rearm
and wait for a while untill appear pop-up with info succesfuly made command,next restart computer again into safe mode and unistall SP2.
If it will interrupt this loop,please navigate to C:\Windows\Logs\CBS find CBS.log file,pack it and upload on RapidShare: 1-CLICK Web hosting - Easy Filehosting
portal
6
#11
slmgr -rearm
The thing is I can't even get into Safe Mode
2,049
#12
:( Sorry but you can only choose these two things:
-reinstall OS
EDIT
I forget you lost all checkpoints too! There is no rescue for you :(:( .
2,049
#14
Do you know where I can get another Windows Vista disc to reinstall with? Can I download one online? Thanks for all your help Flavius
Read this post :( http://www.vistax64.com/1171045-post6.html
Of course if you really want you can also rescue your product key using this tool:Windows XP and Vista Product Key Recovery · Dagon Design
And my personal info:In Vista product key is stored in SOFTWARE (from C:\Windows\System32\config folder) not in NTUSER.DAT! So to read this key you have to load to registry SOFTWARE file
