PNY GeForce 9400 GT
vistablackben
Heya, Hope everyone had good X-Mas!
Been looking at this card, just want to know a few things. It says PNY, is that like a sub-category of Nvidia? I dont understand it! Also will I need to plug in a power cable or will this card get the power from the PCI-E slot itself. And any other thoughts on the card are helpful!
http://www.play.com/PC/PCs/4-/68549...rchstring=PNY+GeForce+9400+GT+&searchsource=0
Thanks, Ben. :)
    AMD Athlon 64 X2 Dual
    Asus nForce 410
    4GB DDR2 667Mhz PC-5300
    GeForfce 6100
    AC'97
    19" Sony
    1024x768
    250GB
    Black
    Air
    Logitech Wireless
    Microsoft Curve
    Up To 16MB
MrNeeds
PC Geek
Play.com (UK) : PNY GeForce 9400 GT / 512MB DDR2 / HDTV-OUT DVI / PCI-E Graphics Card : Computing - Free Delivery
Thanks, Ben. :)
PNY are a company who manufacture the cards, like mine is XFX, and others are like BFG and EVGA, you will need a 6 pin molex PCI-E power cord, which should be included with the card if it requires it.
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Samsung 7200rpm 250Gb SATA,
    Samsung 7200rpm 750Gb SATA,
    WD 7200rpm 1TB SCSI SATA.
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
vistablackben
OK thanks, so the power cord goes into the motherboard and then into the card, sounds straight forward to me.
Ta
    Asus nForce 410
    GeForfce 6100
    AC'97
    19" Sony
    1024x768
    250GB
    Black
    Air
    Logitech Wireless
    Microsoft Curve
    Up To 16MB
MrNeeds
PC Geek
Ta
no, heres a pic of mine lol, to better explain, forgive the doodle its easier to see where my wires are going, i couldnt get a decent picture, my camera is my phone :p
    16Mb Sky bb
stormy13
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
MrNeeds
PC Geek
    16Mb Sky bb
vistablackben
Thanks for the advice again, if i do get the card i should be able to do it, otherwise il post back.
Also the most "graphically intensive" process I will probably run is something like The Sims 2 which runs fine on my on-board. Mainly just want to update for future and larger screen resolution. Therefore a card sub £50 is perfect for me, as im not dreaming of running GTA. Any other card suggestions that meet my criteria then give us a shout and il consider it, as you guys know what your talking about, and really I dont.
Thanks, Ben :cool:
    Asus nForce 410
    GeForfce 6100
    AC'97
    19" Sony
    1024x768
    250GB
    Black
    Air
    Logitech Wireless
    Microsoft Curve
    Up To 16MB
