Printer issue
laurapants
I had an old HP printer so added a parallel port PCI card to my system. The printer shows up as a choice when I go to print. The printer however does not show up under devices and printer folder. I am trying to remove the printer from the system and from showng up as an available printer when I go to print.
richc46
Type services in search
In services look for bluetooth, and set to automatic. I know this sounds crazy, but it works 9 out of 10 times. Unfortunately, you may be number 10. With an old printer it may not employ blue tooth technology. But give it a shot.
laurapants
I had read this somewhere else, but cannot get to bluetooth. Running Wndows 7 home prem 32 bit. Went to devices and drivers and typed bluetooth in search box - says nothing found? Where do I find it
richc46
Go to search, by start button and type services. Bluetooth is in services.
richc46
Found it - thanks, set it to automatic, rebooted the system. Still do not show up. Any other suggestions?
Yes, but not in answer to your question. This is a Vista Forum, you have Windows 7. Why not ask the question, there? The members have expertise in the area of Windows 7 and may be of more help.
Click windows 7 at the top of your screen.
