Problem Event Name: BlueScreen
Hello!
This is the message with the problem details I get after my laptop shuts down and Windows says it has recovered from unexpected shutdown. Attached I am sending the minidump file.
Problem signature:
OS Version: 6.0.6002.2.2.0.768.2
Locale ID: 1033
Additional information about the problem:
BCCode: 1a
BCP1: 00000030
BCP2: 85F0B8E8
BCP3: 8A17B000
BCP4: 9517800C
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
Hi welcome to the forum.
Due to your unexpected crashes & problems. I will contact a forum expert in BSOD's to take a look at your problem.
They are busy people, and because of different time zones are not always immediately available.
Therefore I would ask you to be patient & someone will be along as soon as practical.
Thank you for your patience.
Please download the link below. The expert will no doubt require you to send reports, this may be required for the despatch of said reports.:-
http://www.vistax64.com/crashes-debugging/282419-blue-screen-death-bsod-posting-instructions.html
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
Hello and welcome to the Vista Forums!
Often more than one report is required, because we are primarily looking for patterns in inexact reports. However, I have analysed what you have provided me with.
Although I cannot be certain, it looks as though your BSoD was caused by AVG.
My recommendation would be to remove AVG, and make sure that it cannot be that. If you are un/less willing to do this, then I completely understand, and we can wait for more reports and clues.
I would reccomend the free Microsoft Security Essentials as an excellent alternative (better than AVG many would say, including both security experts and BSoD experts) If you choose this, as I strongly recommend, download the installer from here, and save it to your Desktop: www.microsoft.com/security_essentials
Then download the AVG removal tool from here: Comprehensive List of Uninstallers or Removal Tools for Antivirus Software | Raymond.CC Blog
Restart your computer, and immediately install Microsoft Security Essentials and update it.
Lastly, please tell me what you chose to do about AVG, and if you do receive any more BSoDs, please run this tool instead: http://www.vistax64.com/crashes-debugging/282419-blue-screen-death-bsod-posting-instructions.html
Thanks!
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Done! :)
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
Thank you Richard'
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
Hello!
I did try to uninstall AVG via the given link but it did not remove the program. So I also tried to uninstall it myself which did not work either, for it said there was a missing file. I tried installing it again with the hope to have this missing file back and uninstall it but now it won't work properly again. So I ended up unable to install or uninstall it.
Any suggestions?
Thank you in advance
Shadowjk
Network Enthusiast
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
americancritic
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
#9
Hi!
I removed AVG and installed the suggested anti-virus programmed, updated it. As suggested I tried to download the Debugging tools. But then had BS again. Would it help if I post the new messages with the details...
Problem signature:
Locale ID: 1033
BCCode: 77
BCP1: 00000001
BCP2: 00000000
BCP3: 00000000
BCP4: 8A43F8C0
Service Pack: 2_0
Product: 768_1
Any log is good for examination and analysis.
It is a much more thorough & exact assessment by posting through the BSOD Posting Instruction method.
However if this is not possible, it will have to be whatever you are able to do.
Someone will look through the logs whenever possible & advise of any course of action.
If you can send any BSOD logs by Posting method, that would be good.
Thank you.
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
Shadowjk
Network Enthusiast
The Most Recent Blue screen indicates Memory Corruption so please scan your Memory for any errors
A Minidump only Gives a Hint to the problem and may not be the cause the more I recieve the higher the chance of finding the culprit
Please Upload any other Minidumps that you have to be analysed
Also could you please Disable your Pagefile as this could also be an issue - See http://www.vistax64.com/tutorials/132201-virtual-memory-paging-file-change.html For More Information
For Reference:
Code:
Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Code:
Loading Dump File [C:\Users\Josh\Desktop\Mini040511-01.dmp]
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) UP Free x86 compatible
Built by: 6002.18327.x86fre.vistasp2_gdr.101014-0432
Machine Name:
Kernel base = 0x81c44000 PsLoadedModuleList = 0x81d5bc70
Debug session time: Tue Apr  5 17:24:53.140 2011 (UTC + 1:00)
System Uptime: 0 days 0:30:42.897
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 77, {1, 0, 0, 8a43f8c0}
Probably caused by : memory_corruption ( nt!MiInPageSingleKernelStack+284 )
Followup: MachineOwner
Code:
KERNEL_STACK_INPAGE_ERROR (77)
The requested page of kernel data could not be read in.  Caused by
bad block in paging file or disk controller error.
In the case when the first arguments is 0 or 1, the stack signature
in the kernel stack was not found.  Again, bad hardware.
An I/O status of c000009c (STATUS_DEVICE_DATA_ERROR) or
C000016AL (STATUS_DISK_OPERATION_FAILED)  normally indicates
the data could not be read from the disk due to a bad
block.  Upon reboot autocheck will run and attempt to map out the bad
sector.  If the status is C0000185 (STATUS_IO_DEVICE_ERROR) and the paging
file is on a SCSI disk device, then the cabling and termination should be
checked.  See the knowledge base article on SCSI termination.
Arguments:
Arg1: 00000001, (page was retrieved from disk)
Arg2: 00000000, value found in stack where signature should be
Arg3: 00000000, 0
Arg4: 8a43f8c0, address of signature on kernel stack
Debugging Details:
ERROR_CODE: (NTSTATUS) 0x1 - STATUS_WAIT_1
BUGCHECK_STR:  0x77_1
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  System
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 81cbac78 to 81d11b3f
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
81cbac78 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!MiInPageSingleKernelStack+284
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4cb710d6
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  0x77_1_nt!MiInPageSingleKernelStack+284
Hope This Helps,
Josh
    AMD HD Radeon 6870
    Novatech Night
Great expert advice, & Great Post.
Great Job Josh !
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
Shadowjk
Network Enthusiast
Thank you Kesume :)
    AMD HD Radeon 6870
    Novatech Night
Hi!
How exactly do I scan the Memory for errors?
And while changing the Pagefile it said if I choose to disable it, it might no longer make a record of the errors which may occur. Is that the intention?
Shadowjk
Network Enthusiast
A Pagefile is used when you run low on RAM (Memory) So Disable it for now
To Check your Memory follow the proceedure in the .ZIP File
Then Restart your Computer
Hope This Helps,
Josh
    AMD HD Radeon 6870
    Novatech Night
Shadowjk
Network Enthusiast
Okay - Have you recieved any other Blue Screens since disabling the Pagefile?
    AMD HD Radeon 6870
    Novatech Night
Shadowjk
Network Enthusiast
    AMD HD Radeon 6870
    Novatech Night
Yes, I did have Blue screens today and after that the laptop kept freezing so it was hard to save them and post them here. Actually I re-installed Windows but haven't had the time to use the laptop since then. Will run the check for the hard drive.
richc46
Staff member
Hi!
Be sure about memory, download and use memtest.
http://www.memtest86.com/
