problems instaling latest iTunes
dsoquendo
I have several problems instaling various software updates the first problem involves the latest iTunes update. I get this message during instalation:
Could not open key:
hkey_local_machine32\software\classes\.m4b\openwithlist\itunes.exe
Verify that you have sufficient access to that key, or contact support personnel.
I also have problems instaling the latest Zune 4 update and the latest Adobe reader update. Each give different messages but they have to do with privileges.
Frostmourne
Banned
Right click the app and select run as administrator, which Vista should detect automatically for .exe's. Are you an administrator?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Frostmourne
Banned
Frostmourne,
I try what you told me but when I right click I do not get the "open as administrator" option.
Can you go into User accounts and create another administrator account. Try if it works in that. Then move your data across and delete the administrator account that won't work.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
dsoquendo
Frostmourne,
I have another administrator account. I get the same results. I have tried cleaning the rigistry with a TrendMicro program but no luck.
Frostmourne
Banned
Frostmourne,
I've posted in your otehr thread. Try sfc /scannow. If your registry is corrupted this might fix it.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
dsoquendo
sfc /scannow complete; windows resource protection did not find any integrity violations.
Frostmourne
Banned
Can you run a full system scan with SuperAntiSpyware and Malwarebytes - updating first?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
dsoquendo
Now for some reason any other software i am able to install. I did the install, update and scanning with both programs. there were some issues found by both and were cleaned and removed. No luck installing the iTunes, Adobe reader or Zune updates.
dsoquendo
Getting new message when thrying to upgrade to latest iTunes version. Totally different than the first one posted by myself at the begining of this thread. It reads:
"Could not open key:
HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs. Verify that you have sufficient access to that key, or contact your support personnel."
I dont know if this makes any difference from the first error message but hope someone out there has an answer.
zigzag3143
Banned
go to the folder in the error and take ownership of the folder
here are instrucions Take Ownership Shortcut - Windows 7 Forums
hope this helps
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
blue75
Banned
Try CCleaner / tools that usually uninstalls things I have problems with.If you're looking for a good audio player thats light on resources try aimp2 version 2.11 :)
    gateway
    intel quad
    8 gig
    nvidia
    realtek
    19' widescreen
    1440 x 900
    581 gb
    High speed Comcast cable
