Solved program wont load
168
Location
Inveruno (MI)
Re: programme wont load
What program gives this error?
    AMD Athlon 64 X2 6400+
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    1280x1024@32bit@75MHz
    1 x Seagate 120GB SATA (OS installation)
    1 x Seagate 200GB SATA
    2 x Seagate 320GB SATA (Hardware RAID 0)
    1 x Seagate 250GB IDE (in external USB box)
    1 x TrekStor 750GB USB
    650W
    Logitech Cordless Optical
    Logitech Cordless Desktop EX 100
    8192 kbps / 640 kbps
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
Hello Peter,
As a test, see if right clicking on the program's shortcut and clicking on Run as administrator may help it run properly. If not, then you may also try a Compatibility Mode with it.
Hope this helps for now,
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
PTWW
3
The program is travelmanager. I have right clicked on the short cut and then clicked run as administrator and it works. Thank you for your help.
peter
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
You're welcome Peter.
You can use Compatibility Mode, and check the "Run as admin..." option so that you do not have to right click on the shortcut all the time. :)
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
You're most welcome Peter. :)
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
