RAM Dilemma
lil domii
Seven Guru + GFX
Power User
hey, i have found these two ram sets, £3 apart, and the only difference i see is the ram timings, and i cannot for the likes of me choose which one?
which one should i go for?
Dom
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
smarteyeball
Eye know, eye know
The first one with better timings - for only 3 squid extra, it's an easy choice :)
Basically they are exactly the same RAM modules, except the CL7's are 'better binned' (higher individual quality) than their CL9 counterparts. Modules that can't tolerate tighter timings / voltages are sold as the 'slower' sets.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
archie123
I Tunes hates Me
neither , your cpu fsb is only 800mhz :p
........ you need to tell us the rest of your upgrade products then we can recommend something cheaper , are you planning to overclock?
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
thepizzaman
Banned
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    500gb Seagate SATA II
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
    AVerMedia 1500MCE TV Tuner
lil domii
Seven Guru + GFX
Power User
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
thepizzaman
Banned
hm.... good cpu choice for that :) haha.... although i'd rather have the 965 ;)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
lil domii
Seven Guru + GFX
Power User
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
lil domii
Seven Guru + GFX
Power User
woops sorry didn't think the first one posted :o
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
lil domii
Seven Guru + GFX
Power User
i'm trying to keep to a budget pizzaman! £650 now. phenoms from novatech are like £100 cheapest!
unless i bump the budget to £700...
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
lil domii
Seven Guru + GFX
Power User
can you just up the fsb? or does the clockspeed have to go up with it? i really don't want to go get new processors every 6 months or something like that
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
thepizzaman
Banned
he is talking about your current one the one you will get will be fine.... :D and i know.... i just like the 965 ;)
    1680 X 1050
    6 Mbs Down 1 Mbs Up
lil domii
Seven Guru + GFX
Power User
oh ok i thought you meant the processor i was getting. i am not upgrading my lappy, i'm doing a custom build.
haha dw common mistake.
Dom
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
archie123
I Tunes hates Me
Dom
no mate i had no idea what cpu you were getting thats why i asked ;) , if your using it for gaming could you tell me why your getting an AMD processor?
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
lil domii
Seven Guru + GFX
Power User
Dom
ok here i go :D
i had originally had an intel mobo with intel cpu. thing is, i chose a crossfire config. i had an intel mobo with one pci -ex x16. so i tried to look for a mobo with a crossfire config for around £70. i did, then i found out it was ddr2. i had ddr3 sticks. then i tried to look for mobos with intel sockets, ddr3 ram and crossfire support for £70 again. no luck.
pizzaman recommended amd. i found this mobo. i also got more bang for buck with this cpu.
see why i chose amd now? :)
Dom
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
archie123
I Tunes hates Me
do you want my honest opinion on your choices?? save more get a better motherboard and get an intel cpu an I5 , unless you planning on putting two low end cards in there in crossfire that cpu and mobo chipset will bottleneck your whole rig
you need to balance your purchases out more , i understand your on a budget but you need to do more research
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
lil domii
Seven Guru + GFX
Power User
:confused: i might as well give up on building my own.
i just try and try and never get things right. :(
    Acer 5735z Laptop
    4gb
    Realtek
    1366x768
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
archie123
I Tunes hates Me
no you will get it right mate its a pain in the arse to begin with but you will get there
what have you got now hardware wise? and how much money do you have left to spend? and what do you need? ie psu? case?
its a minefield building on a budget but its doable , you just need to make sure you get a good hardware balance and a good upgrade path , i am always on a budget , its all about research and asking around , but ive been doing alot of that recently so let me help :)
it may turn out you do have to get that mobo and that cpu on your budget buts lets look into it before you spend :)
that was good find though by pizza , a crossfire mobo for 70 quid :)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
thepizzaman
Banned
his budget is about 650 quid.... no way he can build a intel rig that will outperform the triple core for what he can spend, he was going to do a cf setup with two 5770's the triple core, and unless he plans to jump his budget by about 300 quid this is a good rig
    1680 X 1050
    6 Mbs Down 1 Mbs Up
smarteyeball
Eye know, eye know
+ 1
Don't feel dejected mate. A lot of us um and ah over decisions and change our minds repeatedly throughout the process.
I've been toying with upgrading for 6+ months now and I'm still yet to decide on what path I'm taking :rolleyes: :p
The two most important decisions when selecting components:
  1. Decide on a platform (AMD or Intel)
  2. Select your motherboard
Once these two are decided, it makes selecting a CPU and RAM much easier as it eliminates a lot of options. Everything else falls into place after that.
And finally, always have a backup component option in case there is no stock available etc
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
archie123
I Tunes hates Me
come on mate , you HAVE to admit that that mobo and cpu combo will seriously affect the performance of those cards , this needs a bit more thinking , and if needed ......... a bit more saving :) Im not slagging off our choices just offering alternatives :)
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
