icrosoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp11_Windows_NT6_BSOD_jcgriff2[1].zip\Windows_NT6_BSOD_jcgriff2\Mini122410-04.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x64
Built by: 6002.18267.amd64fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0xfffff800`02615000 PsLoadedModuleList = 0xfffff800`027d9dd0
Debug session time: Fri Dec 24 20:43:37.473 2010 (GMT-5)
System Uptime: 0 days 0:04:24.347
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck D1, {ffffffffffffffea, 2, 0, fffffa6000a4b9c6}
Unable to load image \SystemRoot\system32\DRIVERS\iaStor.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for iaStor.sys
*** ERROR: Module load completed but symbols could not be loaded for iaStor.sys
Probably caused by : iaStor.sys ( iaStor+479c6 )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: ffffffffffffffea, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffffa6000a4b9c6, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8000283c080
ffffffffffffffea
CURRENT_IRQL: 2
FAULTING_IP:
iaStor+479c6
fffffa60`00a4b9c6 ?? ???
CUSTOMER_CRASH_COUNT: 4
DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
TRAP_FRAME: fffffa6001bc6a80 -- (.trap 0xfffffa6001bc6a80)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000026161 rbx=0000000000000000 rcx=fffffa8004cfcc28
rdx=fffffa8004cfc000 rsi=0000000000000000 rdi=0000000000000000
rip=fffffa6000a4b9c6 rsp=fffffa6001bc6c10 rbp=fffffa8004cfc000
r8=fffffa6001bc6d50 r9=0000000000000000 r10=0000000000000000
r11=fffffa80040d820c r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
iaStor+0x479c6:
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8000266f26e to fffff8000266f4d0
STACK_TEXT:
fffffa60`01bc6938 fffff800`0266f26e : 00000000`0000000a ffffffff`ffffffea 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffffa60`01bc6940 fffff800`0266e14b : 00000000`00000000 fffff800`02671c7f 00000000`00000000 00000000`00004231 : nt!KiBugCheckDispatch+0x6e
fffffa60`01bc6a80 fffffa60`00a4b9c6 : fffffa80`03cbb818 fffff800`02788cf0 fffffa80`03cbb720 fffff800`027a68f8 : nt!KiPageFault+0x20b
fffffa60`01bc6c10 fffffa80`03cbb818 : fffff800`02788cf0 fffffa80`03cbb720 fffff800`027a68f8 fffffa80`04cfcc88 : iaStor+0x479c6
fffffa60`01bc6c18 fffff800`02788cf0 : fffffa80`03cbb720 fffff800`027a68f8 fffffa80`04cfcc88 fffffa80`04ad71a0 : 0xfffffa80`03cbb818
fffffa60`01bc6c20 fffffa80`03cbb720 : fffff800`027a68f8 fffffa80`04cfcc88 fffffa80`04ad71a0 00000000`00000000 : nt!KiInitialPCR+0x7f0
fffffa60`01bc6c28 fffff800`027a68f8 : fffffa80`04cfcc88 fffffa80`04ad71a0 00000000`00000000 fffffa60`005e8cc0 : 0xfffffa80`03cbb720
fffffa60`01bc6c30 fffffa80`04cfcc88 : fffffa80`04ad71a0 00000000`00000000 fffffa60`005e8cc0 00000000`00000000 : nt!ExWorkerQueue+0x58
fffffa60`01bc6c38 fffffa80`04ad71a0 : 00000000`00000000 fffffa60`005e8cc0 00000000`00000000 00000000`00000001 : 0xfffffa80`04cfcc88
fffffa60`01bc6c40 00000000`00000000 : fffffa60`005e8cc0 00000000`00000000 00000000`00000001 fffffa80`06382fc0 : 0xfffffa80`04ad71a0
STACK_COMMAND: kb
FOLLOWUP_IP:
iaStor+479c6
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: iaStor+479c6
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: iaStor
IMAGE_NAME: iaStor.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4805479b
FAILURE_BUCKET_ID: X64_0xD1_iaStor+479c6
0: kd> LMTSMN
Unknown option 'T'
Unknown option 'S'
start end module name
0: kd> lmtsmn
fffffa60`0270e000 fffffa60`0271df00 1394BUS 1394BUS.SYS Sat Jan 19 01:34:04 2008 (479199DC)
fffffa60`008f1000 fffffa60`00947000 acpi acpi.sys Sat Apr 11 01:03:26 2009 (49E0249E)
fffffa60`00b12000 fffffa60`00b1a000 atapi atapi.sys Tue Mar 11 23:05:04 2008 (47D74860)
fffffa60`00b1a000 fffffa60`00b3e000 ataport ataport.SYS Sat Jan 19 01:28:52 2008 (479198A4)
fffff960`00af0000 fffff960`00b51000 ATMFD ATMFD.DLL unavailable (00000000)
fffffa60`009d4000 fffffa60`009e0000 BATTC BATTC.SYS Sat Jan 19 01:02:38 2008 (4791927E)
fffffa60`03342000 fffffa60`0335e000 cdfs cdfs.sys Sat Jan 19 00:53:45 2008 (47919069)
fffffa60`02380000 fffffa60`0239c000 cdrom cdrom.sys Sat Apr 11 01:34:39 2009 (49E02BEF)
fffffa60`006b5000 fffffa60`00767000 CI CI.dll Sat Apr 11 03:08:09 2009 (49E041D9)
fffffa60`00fcd000 fffffa60`00ff9000 CLASSPNP CLASSPNP.SYS Sat Apr 11 01:34:15 2009 (49E02BD7)
fffffa60`00658000 fffffa60`006b5000 CLFS CLFS.SYS Sat Apr 11 00:54:21 2009 (49E0227D)
fffffa60`009d0000 fffffa60`009d3400 compbatt compbatt.sys Sat Jan 19 01:02:42 2008 (47919282)
fffffa60`0335e000 fffffa60`0336c000 crashdmp crashdmp.sys Sat Apr 11 01:34:31 2009 (49E02BE7)
fffffa60`013ed000 fffffa60`013f7000 crcdisk crcdisk.sys Sat Jan 19 01:30:12 2008 (479198F4)
fffffa60`011dc000 fffffa60`011f0000 disk disk.sys Sat Apr 11 01:34:38 2009 (49E02BEE)
fffffa60`03200000 fffffa60`0330e000 dump_iaStor dump_iaStor.sys Tue Apr 15 20:26:03 2008 (4805479B)
fffffa60`03336000 fffffa60`03342000 Dxapi Dxapi.sys Sat Jan 19 01:08:00 2008 (479193C0)
fffff960`00440000 fffff960`0045e000 dxg dxg.sys unavailable (00000000)
fffffa60`011b0000 fffffa60`011dc000 ecache ecache.sys Sat Apr 11 01:36:18 2009 (49E02C52)
fffffa60`00b85000 fffffa60`00b99000 fileinfo fileinfo.sys Sat Jan 19 01:05:23 2008 (47919323)
fffffa60`00b3e000 fffffa60`00b85000 fltmgr fltmgr.sys Sat Apr 11 00:54:38 2009 (49E0228E)
fffff960`008b0000 fffff960`008b9000 framebuf framebuf.dll unavailable (00000000)
fffffa60`02200000 fffffa60`0220a000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:53:41 2008 (47919065)
fffffa60`01184000 fffffa60`011b0000 fwpkclnt fwpkclnt.sys Sat Apr 11 01:42:44 2009 (49E02DD4)
fffffa60`027ed000 fffffa60`027f8000 GEARAspiWDM GEARAspiWDM.sys Thu Mar 19 11:34:13 2009 (49C265F5)
fffff800`02b2c000 fffff800`02b72000 hal hal.dll Sat Apr 11 03:04:56 2009 (49E04118)
fffffa60`0260f000 fffffa60`026fc000 HDAudBus HDAudBus.sys Sat Apr 11 01:39:38 2009 (49E02D1A)
fffffa60`02766000 fffffa60`0277c000 i8042prt i8042prt.sys Sat Jan 19 01:28:08 2008 (47919878)
fffffa60`00a04000 fffffa60`00b12000 iaStor iaStor.sys Tue Apr 15 20:26:03 2008 (4805479B)
fffffa60`0277c000 fffffa60`0278a000 kbdclass kbdclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`00606000 fffffa60`00609000 kdcom kdcom.dll Tue Nov 30 09:40:39 2010 (4CF50CE7)
fffffa60`00d99000 fffffa60`00dcd000 ks ks.sys Sat Apr 11 01:33:51 2009 (49E02BBF)
fffffa60`00c0c000 fffffa60`00c93000 ksecdd ksecdd.sys Mon Jun 15 09:15:18 2009 (4A364966)
fffffa60`00609000 fffffa60`00644000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 03:05:41 2009 (49E04145)
fffffa60`027e1000 fffffa60`027ed000 mouclass mouclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`007cd000 fffffa60`007e0000 mountmgr mountmgr.sys Sat Jan 19 01:28:01 2008 (47919871)
fffffa60`00df2000 fffffa60`00dfd000 Msfs Msfs.SYS Sat Jan 19 00:53:55 2008 (47919073)
fffffa60`00950000 fffffa60`0095a000 msisadrv msisadrv.sys Sat Jan 19 01:02:50 2008 (4791928A)
fffffa60`0239c000 fffffa60`023d5000 msiscsi msiscsi.sys Sat Apr 11 01:36:09 2009 (49E02C49)
fffffa60`00c93000 fffffa60`00ce3000 msrpc msrpc.sys Sat Apr 11 01:32:13 2009 (49E02B5D)
fffffa60`023f5000 fffffa60`02400000 mssmbios mssmbios.sys Sat Jan 19 01:02:54 2008 (4791928E)
fffffa60`013db000 fffffa60`013ed000 mup mup.sys Sat Apr 11 00:54:47 2009 (49E02297)
fffffa60`00e0a000 fffffa60`00fcd000 ndis ndis.sys Sat Apr 11 01:43:15 2009 (49E02DF3)
fffffa60`00ce3000 fffffa60`00d3c000 NETIO NETIO.SYS Sat Apr 11 01:43:34 2009 (49E02E06)
fffffa60`007e0000 fffffa60`007f1000 Npfs Npfs.SYS Sat Apr 11 00:54:22 2009 (49E0227E)
fffff800`02615000 fffff800`02b2c000 nt ntkrnlmp.exe Tue Jun 08 10:59:47 2010 (4C0E5AE3)
fffffa60`0120f000 fffffa60`0138f000 Ntfs Ntfs.sys Sat Apr 11 00:55:38 2009 (49E022CA)
fffffa60`013f7000 fffffa60`01400000 Null Null.SYS Thu Nov 02 05:37:15 2006 (4549BC4B)
fffffa60`02758000 fffffa60`02765c80 o2mdx64 o2mdx64.sys Mon May 12 23:47:07 2008 (48290F3B)
fffffa60`0271e000 fffffa60`02729300 o2sdx64 o2sdx64.sys Tue Jun 10 07:26:44 2008 (484E64F4)
fffffa60`026fc000 fffffa60`0270db00 ohci1394 ohci1394.sys Sat Apr 11 01:39:49 2009 (49E02D25)
fffffa60`0098a000 fffffa60`0099f000 partmgr partmgr.sys Sat Apr 11 01:34:51 2009 (49E02BFB)
fffffa60`0095a000 fffffa60`0098a000 pci pci.sys Sat Apr 11 01:03:33 2009 (49E024A5)
fffffa60`00644000 fffffa60`00658000 PSHED PSHED.dll Sat Apr 11 03:08:17 2009 (49E041E1)
fffffa60`0272a000 fffffa60`02758000 SCSIPORT SCSIPORT.SYS Sat Jan 19 01:28:52 2008 (479198A4)
fffffa60`0099f000 fffffa60`009ac000 ssfs0bbc ssfs0bbc.sys Fri Nov 06 14:39:46 2009 (4AF47B82)
fffffa60`009ac000 fffffa60`009d0000 ssidrv ssidrv.sys Fri Nov 06 14:39:15 2009 (4AF47B63)
fffffa60`00d3c000 fffffa60`00d99000 storport storport.sys Sat Apr 11 01:34:45 2009 (49E02BF5)
fffffa60`02609000 fffffa60`0260a480 swenum swenum.sys Thu Nov 02 05:37:33 2006 (4549BC5D)
fffffa60`0278a000 fffffa60`027df000 SynTP SynTP.sys Fri Jan 18 13:50:49 2008 (4790F509)
fffffa60`0100e000 fffffa60`01184000 tcpip tcpip.sys Wed Jun 16 10:51:56 2010 (4C18E50C)
fffffa60`023d5000 fffffa60`023e2000 TDI TDI.SYS Sat Apr 11 01:44:14 2009 (49E02E2E)
fffffa60`023e2000 fffffa60`023f5000 termdd termdd.sys Sat Apr 11 01:48:13 2009 (49E02F1D)
fffff960`00660000 fffff960`0066a000 TSDDD TSDDD.dll unavailable (00000000)
fffffa60`011f0000 fffffa60`01200000 umbus umbus.sys Sat Jan 19 01:34:16 2008 (479199E8)
fffffa60`0331a000 fffffa60`03336000 usbccgp usbccgp.sys Sat Jan 19 01:34:04 2008 (479199DC)
fffffa60`027df000 fffffa60`027e0e00 USBD USBD.SYS Sat Jan 19 01:33:53 2008 (479199D1)
fffffa60`0236f000 fffffa60`02380000 usbehci usbehci.sys Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`00b99000 fffffa60`00be1000 usbhub usbhub.sys Sat Apr 11 01:39:52 2009 (49E02D28)
fffffa60`02329000 fffffa60`0236f000 USBPORT USBPORT.SYS Sat Apr 11 01:39:39 2009 (49E02D1B)
fffffa60`0231d000 fffffa60`02329000 usbuhci usbuhci.sys Sat Jan 19 01:33:56 2008 (479199D4)
fffffa60`01000000 fffffa60`0100e000 vga vga.sys Sat Jan 19 01:32:21 2008 (47919975)
fffffa60`00dcd000 fffffa60`00df2000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 01:32:25 2008 (47919979)
fffffa60`009e0000 fffffa60`009f4000 volmgr volmgr.sys Sat Apr 11 01:34:49 2009 (49E02BF9)
fffffa60`00767000 fffffa60`007cd000 volmgrx volmgrx.sys Sat Apr 11 01:35:14 2009 (49E02C12)
fffffa60`0138f000 fffffa60`013d3000 volsnap volsnap.sys Sat Apr 11 01:35:33 2009 (49E02C25)
fffffa60`00be1000 fffffa60`00bf1000 watchdog watchdog.sys Sat Apr 11 01:09:16 2009 (49E025FC)
fffffa60`00809000 fffffa60`008e3000 Wdf01000 Wdf01000.sys Sat Jan 19 01:33:27 2008 (479199B7)
fffffa60`008e3000 fffffa60`008f1000 WDFLDR WDFLDR.SYS Sat Jan 19 01:32:33 2008 (47919981)
fffff960`00080000 fffff960`00334000 win32k win32k.sys unavailable (00000000)
fffffa60`02600000 fffffa60`02609000 wmiacpi wmiacpi.sys Sat Jan 19 01:02:42 2008 (47919282)
fffffa60`00947000 fffffa60`00950000 WMILIB WMILIB.SYS Sat Jan 19 01:33:45 2008 (479199C9)
