Rate my rig
Redfoxm18
Hey guys I am new to forum and new to Vista. I just built my first computer with help and advice from a friend and just am wondering what you think.
ASUS M3A78 AM2+/AM2 AMD 770 ATX AMD Motherboard
GeForce 9800 GTX(G92) 512MB 256-bit GDDR3
AMD Athlon 64 X2 6000+ Windsor 3.0GHz
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
SAMSUNG Spinpoint F1 HD502lJ 500GB 7200 RPM 16MB Cache
OCZ StealthXStream OCZ500SXS 500W
So far it is running beautifully with Vista. No hiccups. All drivers recognized. I built this system because I hadn't upgraded my POS dell since I got it in '02 and it officially bit the dust the other day. I also wanted to be able to play all the top of the line games that are out especially Fallout 3. Anyway I just wanted to know if anyone has a similar setup and how it has been treating them.
    Antec 300
Redfoxm18
Anyone?
    Antec 300
bruce2
Vista Pro
Hi Redfoxm18, welcome to the board.
Don't see any answer, let me try.
First, congrat on your new built and without any glitches.
It is really difficult to give you a straight answer because I usually run into this sort of question before the system is built. So.......it really depends on how high you like your setting for your gaming. Looking at your spec, it will handle all the new games out there, but there are always room for improvement. For example, if you are looking for upgrade or something one day, your psu could have been bigger,as such. Good luck and enjoy!
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
smarteyeball
Eye know, eye know
Congrats redfox, all I can say is that it's better specced than mine :)
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
    Laptop Specs:
    Clevo Sager P170HM //
    17.3 Matte 1920x1200 //
    i7 2720QM // 8GB 1333mhz //
    Dedicated GTX 485M //
    Samsung Story 2TB USB 3.0
mansrm81
Same here good job. Wish I had a 6000+ cpu.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Redfoxm18
Thanks for the high praise guys. It is encouraging. The PSU in the end looking back on it was my only real concern but it seems to be running well. I'm picking up Fallout 3 after work today so I will really give my system a workout when I get home and see how it performs.
On a side note does anyone know the EVGA software that comes with 9800 really well and what can I tweak the settings too without putting major strain on my card? I upped the fan from 35% it comes set at to 65% which helps with cooling while playing WoW which is the only game Ive tested extensively on my rig. I can put on full visual settings and my core temp does not get above 42C and the graphics card has not reached above 55C.
    Antec 300
AstaLaVista
Lost in Cyberspace
Vista Pro
I am jealous, that's pretty much all I can say. ;)
+1 on the PSU, with that big of a monster, you could have gone for a 750/1000w and not have to upgrade until 2015 :p :D
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    WD Velociraptor 160GB
    Samsung Sata 750GB
    Maxtor External 160GB
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
Redfoxm18
The scary part is I spent more than double what I spent on this when I got my dell for college in 2002. Besides what was mentioned earlier I sprung for Vista (obviously), a wireless router for my house, wireless card for my rig, and 22x DVD/DVD Writer drive. Total cost including shipping off of newegg.com $920.75.
    Antec 300
SCSIraidGURU
Seems OK. Its stable. Does everything you want?
    16GB DDR667
    SAS RAID
Redfoxm18
It handles mutliple processes with ease which is great cause I'm usually downloading music, playing a game, running music, ad have several applications running in the background. It's real test will be when I bring home Fallout 3 and crank it way up :)
    Antec 300
SCSIraidGURU
I was looking at a 4870x2 for highend gaming cranked to maximum.
    16GB DDR667
    SAS RAID
Redfoxm18
Damn way outta my price range. I don't think you would have to update for a real long time if you got that.
    Antec 300
SCSIraidGURU
My workstation is updated constantly for my A/V and CAD work.
    16GB DDR667
    SAS RAID
Redfoxm18
Ah very cool. What type of business do you do that work for?
    Antec 300
