Solved Repair your computer option missing from advanced boot menu
On a friend's computer, when I access the advanced boot menu using F8, the repair your computer option is missing. I found this info on a Microsoft page:
Shows a list of system recovery tools you can use to repair startup problems, run diagnostics, or restore your system. This option is available only if the tools are installed on your computer's hard disk.
Does anyone know if these tools can be installed on a computer that is missing them? This is an Asus laptop.
Thanks
djch129
Banned
Thanks
I don't possess such deep knowledge to answer your question.
Perhaps the following link will be of interest to you :
Lost "Repair My Computer" Option in F8 Boot Advanced Startup Options Menu
Lost "Repair My Computer" Option in F8 Boot Advanced Startup Options Menu - Vista Setup and Install
  • Other Info
    WLM 2011
    IE9 beta
Shadowjk
Network Enthusiast
Thanks
You Can Burn the Tools onto a CD (BE WARNED THIS IS NOT AN INSTALLATION DISK)
You Will need the Following:
  1. A Computer
  2. Another Computer with an Internet Connection
  3. A ISO Image of the Tools *Download Link*
  4. An ISO Burner
  5. A Blank CD/DVD
Once you have obtained the Requirements then you can Follow this tutorial
See http://www.vistax64.com/tutorials/141820-create-recovery-disc.html?ltr=C For More Information
If you need an ISO Burner then Please Ask All Details are inside the Link
Hope This Helps,
Josh
  • Name
    Josh Kingsbury
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW ([email protected])
    Novatech Night
    Dell HID-compliant mouse
    Occupation
    Student - Level 3 Extended Diploma in IT (System S
    Country Flag
    uk
    State/Region Flag
    uk england
Lorien
Account Suspended
I suspect this is a bit too advanced (it would be hard for me - I don't think even I would attempt this) and requires additional steps which aren't documented in the article (but can be separately researched if you want to pursue it), but here's an article on how to add RE to the F8 command: How to install Windows RE on the hard disk - Windows RE Notes - Site Home - MSDN Blogs.
You will probably have many questions and I'm not sure I can answer them as this is a somewhat complex process and involves knowing quite a bit how the system operates and which of the options it suggests is best (and I'm not sure I can advise you on that as just understanding the article and the links it sent me to was pretty much near the upper reaches of skills).
Personally, I recommend you don't try this on your own, but hire a professional engineer skilled in Microsoft development and deployment tools as well as Vista (at the very least) if you really want it done. I've been doing this sort of thing for a living for nearly 20 years, and I'm not sure if I'd accept this job if I were requested to do so. Still, if you're going to try it yourself, I recommend you spend a great deal of time reading the MSDN knowledge base on everything you can find about Windows OPK and Windows AIK and WIM-based installations before you even look at the above article since it assumes you already have that knowledge. You may also need to re-partition your hard drive (or otherwise use a different partition or even a different drive than the system partition since if the system partition fails, you still want the Win RE tools to work).
In my opinion, even though this technical answers your question (to a degree - without the step-by-step instructions I'd provide if I understood enough to write them out or could find sources providing that level of detail), I STRONGLY recommend you simply follow Shadow's advice and create a Recovery Disk and use that if/when needed rather than messing around with trying to add the features to the F8 button. I almost didn't post this because I am concerned that doing anything wrong in the attempt (and that's a serious possibility) could hose your system to the point that only a clean install could recover (so if you do try, do a full backup first and create a restore point and be prepared to need to re-install Vista from scratch and lose everthing on the hard drive). F8 doesn't always work either and then you need to use the disk anyway - so the disk is frankly a better Recovery option and tool.
I hope this helps and explains things and you decide to go simply with the disk and set aside the option of enhancing the F8 button.
Good luck!
    1920 x 1200 pixels
    Occupation
    Computer repair company owner - 19+ years
    Dell AIO Printer A940
    6TO4 Adapter
    Microsoft ISATAP Adapter
    Router Linksys / WRT54G -01
    Country Flag
    usa
    State/Region Flag
    us maryland
Shadowjk, if the recovery disc will provide the same tools then I will just go that route, thanks.
Lorien, I'll take your advice and avoid the installation procedure.
Thanks to both of you for the information.
Shadowjk
Network Enthusiast
No Problem be warned to access the Tools you will need to Enter the Information when the Computer boots up into the disk and then click Repair My Computer in the Bottom Left hand corner
Also Thank you for the Reputation for it is Deeply Appreciated
Many Thanks,
Josh
  • Name
    Josh Kingsbury
    AMD HD Radeon 6870
    Novatech Night
    Occupation
    Country Flag
    uk
    State/Region Flag
    uk england
Lorien
Account Suspended
It was our pleasure. I'm glad we could be of assistance - and I'm pleased you've decided to avoid that installation procedure. As I said, even with my experience I would hesitate before doing it. And the disk is probably a better option anyway as if the hard drive is the problem, the F8 process may not function either and that wouldn't be good.
I too appreciate that you took the time to tip the scales - thank you.
Good luck and best wishes.
P.S. Remember, we're always here if you need us for anything or simply have a question or maybe even want to post a few answers as you're Skilled yourself.
    1920 x 1200 pixels
    Occupation
    6TO4 Adapter
    Country Flag
    usa
    State/Region Flag
    us maryland
utrix
“Repair your computer” option disappeared from “advanced boot” menu in “Vista Advanced Boot Options window“.
The Repair Your Computer option appeared in July 2012, but now does not. Why?
Madhur B
Dell Social Media Team
There are two ways to add windows RE on the computer:
Option 1:
You can follow the steps to add windows RE on the computer: How to install Windows RE on the hard disk - Windows RE Notes - Site Home - MSDN Blogs
Option 2:
1. Run "command prompt" as administrator. To run "command prompt” click start in search type in cmd, right-click "cmd" and selecting "Run as administrator". Please use the following link for detailed instructions to run command prompt as Administrator http://www.vistax64.com/tutorials/181765-elevated-command-prompt.html
2. Enter "reagentc/info" in the opening command, press "Enter" and the relevant information of Windows RE appears. If the value of "Windows RE enabled" is 0 then Windows RE is disabled.
3. If it is “0” type "reagentc/enable" and press "Enter" to enable Windows RE.
4. Check if it is able to show Repair your computer in F8.
Please post back with the results.
  • Name
    Madhur Bung
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
    Occupation
    I work for Dell Social Media Response Team
    Country Flag
    india
utrix
Hello,
Thank you for responding.
1. Start
2. In Start Search I typed cmd
3. Right click on command prompt
4. Click on Run as Administrator
5. C:\Windows\system32>
6. Typed reagentc/info
C:\Windows\system32>reagentc/info
'reagentc' is not recognized as an internal or external command,
operable program or batch file.
Thank you,
Ron
SIW2
Madhur got mixed up there.
Vista doesn't have reagentc.exe
When I get a few moments, I will make something so Vista users can get the recovery options on their boot menu - and run them off on cd/usb.
Probably won't be today tho.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
Madhur B
I apologize; the steps are for windows 7 not for vista.
Thanks for helping me understand.
  • Name
    Madhur Bung
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
    Occupation
    Country Flag
    india
cnfcomps
Option 1:
Option 2:
Many thanks - this helped me greatly on a Windows 7 machine.
