Restore Previous Versions - Restore or Remove from Context Menu
ByLine
How to Restore or Remove "Restore Previous Versions" from the Vista Context Menu
Synopsis
This will allow you to restore or remove the Restore Previous Versions menu item from the context menu for all users.
Previous Versions is only available for the Ultimate, Business, and Enterprise editions of Windows Vista. For the other Vista editions, you might try this free alternative: http://www.shadowexplorer.com/
EXAMPLE: "Restore Previous Versions" before and after Removed from the Context Menu
1. To Remove "Restore Previous Versions" from the Context Menu
A) Click on the download button below to download the​
Remove_Previous_Versions_Context_Menu.reg file.​
download
B) Go to step 3.​
2. To Restore "Restore Previous Versions" to the Context Menu
Restore_Previous_Versions_Context_Menu.reg file.​
download
4. Right click on the .reg file (on Desktop) and click on Merge.​
5. Click on the Run button in the Security Warning pop-up.​
6. Click on Continue (UAC), Yes, and then OK when prompted.​
7. When done, you can delete the .reg file (on Desktop).​
Related Tutorials
  • Remove_Previous_Versions_Context_Menu.reg
  • Restore_Previous_Versions_Context_Menu.reg
ollyau
Is this normally enabled by default?
I never remember seeing it before, but I see it now.
The reason I ask is that I had used 'System Restore' to fix my right click context menu, which for an unknown reason, seemed to be reset and none of my custom entires were there, such as the Windows Live OneCare 'Scan for viruses' and the WinRAR options also.
    AMD Phenom X4 9850 2.5 GHz
    ASUS M3N-HD / HDMI
    4.00 GB
    nVidia GeForce 8800 GTS 640
    500 GB
Brink
Staff member
mvp
Hi Ollyau,
Yes, Restore Previous Versions is in the context menu by default in Vista.
Some common things that may reset or mess with the context menu to see if you did recently are a Windows Update, another just added context menu item from some program, and malware.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Katrocks
I have a problem, my context menu was fine, but now when I click on a file it does not display all the items anymore, It displays all items only when I click on a folder but not on a file. any suggestions? :confused::cry:
Brink
Staff member
mvp
    Lumia 1520 phone
MrElectrifyer
Electrical Engineer
Hi admin Brink
I just have a question related to this Post and context menus.
Is this only for windows vista ultimate or can I use it in home premium?
Do you know a way to create a shortcut (in the context menu of FOLDERS) that opens the change icon window for the folder I right click on?
I have created a lot of folder icons for the different programs I have installed and I want to apply them to the appropriate folders. Unfortunately it gets kind of irritating when I have to perform the same 5 steps over and over again for each and every folder.
Please reply ASAP, thank you
    HP Pavilion dv3510nr Entertainment Notebook PC
    Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz
    Inventec 1505
    4.00GB
    NVIDIA GeForce 9300M GS
    Generic PnP Monitor
    WDC WD3200BEVT-00ZCT0
    Alps Pointing-device
    Standard 101/102-Key or Microsoft Natural PS/2 Keyboard with
Brink
Staff member
mvp
Hello Mr. Electrifyer,
Sorry, but Previous Versions is only available for the Ultimate, Business, and Enterprise editions of Windows Vista. :(
    Lumia 1520 phone
MrElectrifyer
Electrical Engineer
Ok, but do you know of a way to add a "change icon" shorcut to the context menu of folders?
    Inventec 1505
    4.00GB
    Generic PnP Monitor
Brink
Staff member
mvp
    Lumia 1520 phone
