You should upgrade or use an
alternative browser .
Solved secpol.msc does not exist
Its not urgent, i just wanted to fiddle around with some settings but when i look for the Local Security Policy it is not in administrative tools and when i try to run secpol.msc it says windows cannot find it*
there is however a file in C:\Windows\System32 that is called SecEdit.exe but that just brings up a cmd window for a fraction of a second
any ideas on how to access this snap-in??
thanks
*i used
http://www.vistax64.com/tutorials/222867-local-security-policy-editor-open.html to try and locate it initially
Advent 9515
AMD Turion 64X2 2.0GHz
2GB
ATI Radeon X1250
Should be 10Mbps, often less
Hello Maccaquacker,
Sorry, but since you have Vista Home Premium....
From link above:
Warning
The Local Security Group Policy Editor will only be available in the Vista Business, Ultimate, and Enterpise editions. You will not have the Local Security Policy Editor available in the Vista Home Basic and Home Premium editions.
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
Galaxy S23 Plus phone
Operating System
The Contemplator
What is it that you are trying to do?
Dwarf Dwf/11/2012 r09/2013
ASRock Z77 Extreme4-M
ViewSonic VA1912w Widescreen
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Yes, perhaps we may be able to find an alternative way for you to do it.
Operating System
Operating System
Ah, sorry, I didn't see that
It does not matter, just wanted to fiddle around, nothing essential
Advent 9515
2GB
ATI Radeon X1250
Ok. Please feel free to ask us if you do later.
Operating System
Operating System
