Skydrive can't be run with full administrative rights
wither 3
When I try to run the .exe file to set up Skydrive, it gives me the above message. When I go to it's properties and select the Security tab, it shows the system and two administrators with full rights. If I deny full control to both administrators, the setup says I don't have permission to run it.
Kind of a catch 22.
Has anyone else encountered this? If so, what is the fix?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Hello Wither,
You'll need to set permissions rights for the .exe file back to full control.
This may be a "Run as administrator" (elevated) issue instead.
Is your user account an elevated account (ex: built-in "elevated" Administrator account)? If so, try running the .exe from a normal unelevated administrator account instead.
Double check using step 7 in the tutorial below to make sure that the Run this program as an administrator box is unchecked in Compatibility Mode settings.
In addition, do not use "Run as administrator" when you right click on the .exe.
Hope this helps, :)
    Logitech MX Master 4
Thanks Brink-
No, I'm not using an elevated user account. It's the same level as when you first install the OS. I also always have UAC turned off.
I had actually tried running it as the administrator and got the same error.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I was looking on the web and found that UAC has to be on to run it. However, I turned UAC on and rebooted and got the same error.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Yep. Everything is set properly.
This is the link where I found out about the UAC- Error Message: "SkyDrive can't be run using full - Microsoft Community
If I remember correctly, it provides an elegant solution involving creating administrator accounts but I've decided I'm not interested. I frequently upload files for otheres to download at hotfile.com and depositfiles.com but their upload and download speeds are awful.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
