Solved System Upgrades
Bare Foot Kid
R.I.P. August 13th 2014
Hello y'all
I have been saying I was going to do it, so now I have!
I ordered these components from Newegg 12 June (yesterday).
Today I received conformation that the order was packed and tracking
numbers were issued, shipping from two different origins.
EVGA 1GB 9600GT - OCZ 700W PSU - HANNS-G 22" LCD Monitor to go with my 47" 1920x1080P Monitor/TV
The monitor will be here Tuesday the GFX Card & PSU will be here Wednesday!
I would really like to install the PSU myself; any suggestions?
All comments welcome.
Thanks to all!
Later :cool: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
Congrats ! :)
Enjoy ur new stuff !
Altho i dont think 1GB really matters on the 9600GT ?
Installing PSU is quite easy BUT if you've never done it i suggest you take a snapshot or something of the current PSU connections and then install the new one accordingly
(Dunno about the OCZ but some Manufacturers do not provide a manual for installation)
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
The main thing you have to do is plan for removal and installation. Some cases have things that get in the way, like ThermalTake's Armour line having he USB et. al on *top* of the case as opposed to in front.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Installing a new psu is the most cable intensive part.
Take out the old PSU.
Take out the graphics card.
if your psu is modular I would connect the cables first to the HD and motherboard before connecting to the psu (This will allow for better cable management.)
If the psu is not moduler install the psu first before connecting any cables.)
Connect the power cables to the graphics card before you install it if possible. You have an antec case so this is quite inportant as it may be a tight fit otherwise.
After you have installed everything think about airflow. When having cables in a computer, can you hide some behind the motherboard. Tie wrap some of the cables to the side of the hard drive bays, use an unused harddrive bay for cables not being used, one of the top 3 if possible again because of the bottom 2 fans.
There may also be a connector on some motherboards for a graphics card.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
Hello Roy, how you doing?
I want to thank you for taking time to respond to this.
I am concerned that this may be over my head simply because I have
no experience doing anything like this. I will learn as time goes by but I
don't think a big project like a PSU is the place to start.
I'll probably take it to someone who knows what they're doing.
I do want to thank You, John and Asky for the encouragement!
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
I may have made things sound more complicated than they are, my wife tells me off for this all the time:o. Installing a PSU is not to bad. Once you have got a friend to help you with it, dont get them to do all the work otherwise you will not learn, you will also realise how easy it is. You can not plug the wrong cable in as the cables only fit the devices they are designed for. Take things 1 item at a time and make a list of what you have.
i.e.
1 HD 1 power point
1 DVD RW 1 power point
1 gfx card 1 or 2 power points
1 mobo (power points depend on make)
Case fans 4 power points. (some of the fans may be plugged into the mobo)
As you link up each power point mark it off your list.
:geek:
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
nice monitor....:D:D
just make sure when installing the PSU try & keep 1 finger on the underside of the PCB when applying pressure for connection
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech EX110
    logitech cordless optical
    2mb
I almost bought 2 of those from NewEgg.com 2 nights ago - they had a special $50 off for some reason....but it was for that one day only....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Hello again everyone!
Well got the monitor last week and I love it, very nice!
I RMA'd the EVGA card back (didn't even open it) and got the card I wanted to
get in the first place...
THIS CARD has one DVI and one HDMI out, since I want my 47" (no DVI in) to
be my second monitor there's no reason to have to use an adaptor the 47" has
four HDMI's in. Not to mention it's about 75.00 less... :party: !
Plus the EVGA was way more card than I'll ever use.
I"ll probably 'wimp out' and let someone that REALLY knows what they're doing
install the PSU, oh well tomorrows' another day. I'll learn sooner or later.
Thank you all!
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Check out the ATI 4870 for $309, if you can afford it. I would also get the PC Power and Cooling Silencer 750W power supply. It is single rail 12V.
    16GB DDR667
    SAS RAID
I can afford anything I want... ;)
I already have the PSU and Card I want!
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Ted stop being a wimp and get that PSU installed.
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Hello John... :p
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Installing a PSU is simple, if you are going to learn start there.
    Ryzen 9 5950X
    Creative
    Drive
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
I know you're right, it's just sitting there staring at me... :cry:
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
I have a 1000W PC Power and Cooling 1kW-SR on its own 20A circuit and 20A 2400W line conditioner. I think my workstation is becoming self aware. It wants to be called Colossus.
    16GB DDR667
    SAS RAID
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Heh - congrats.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
hi there ted.......:)
How to Install an ATX Power Supply
Installing an ATX power supply in a new computer case or an old computer case. You will need a screw driver set and possibly wire cutters.
Steps
  1. Unplug the power from the ATX power supply, if there is currently a power supply installed in the computer.
  2. Remove the side panel from the computer tower. These are usually shut by thumb screws, which you can easily remove, but you may require a Phillips head screw driver.
  3. Assess the position of the current power supply in the case. That is, is it installed length-wise, or width-wise?
  4. Unplug all connections from the power supply to components in the computer.
  5. Remove the screws from the power supply at the rear of the case.
  6. Slowly and carefully remove the power supply.
  7. Take the new power supply and work it into the position of the old power supply.
  8. Reinstall the screws that hold power supply in the case.
  9. Return all power connections to devices in the computer.
  10. Plug in the power supply.
  11. Turn on the computer and boot.
  12. Turn off the computer.
  13. Return the side panel to the computer and reinstall screws to hold side panel in place.
Tips
  • If there are obstructions when removing the power supply, (e.g. a video card, the processor heatsink), only remove them if it is absolutely necessary. If not, try to work the power supply around them.
  • There may be tie straps in the case, which may need to be cut.
  • Test all components on your computer before returning the side panel and reinstalling the outer screws.
Warnings
  • Remember that all power supplies contain various capacitors inside of them that retain power even after it has been turned off. Never open up or insert any metal objects into the vents of it, as you can risk electrical shock.
  • When removing power supply screws, hold on to power supply. The torque from removing one screw can affect the removal of the others.
  • Check twice, cut once before removing any tie strap restraints. You do not want to clip a power cable by accident!
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
