A big thanks for the continued help, Noel.
AVG remover had a problem and quit working.
Here is the log:
2014-03-02 11:00:05,175 INFO SystemChecking started.
2014-03-02 11:00:17,452 DEBUG Cannot open AvgUninstall key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Avg8Uninstall\Directories (error: e0010013)
2014-03-02 11:00:17,452 DEBUG Cannot open AvgUninstall key SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Avg9Uninstall\Directories (error: e0010013)
2014-03-02 11:00:17,452 WARN AvgDir parameter is empty, but Remover found AvgDir at 'C:\Program Files\AVG\AVG2012', use this path as default.
2014-03-02 11:00:17,452 WARN AvgDataDir parameter is empty.
2014-03-02 11:00:17,452 DEBUG Cannot open AvgUninstall key SOFTWARE\AVG\AVG IDS\IDS (error: e0010013)
2014-03-02 11:00:17,452 DEBUG Cannot open AvgUninstall key SOFTWARE\AVG SafeGuard toolbar (error: e0010013)
2014-03-02 11:00:17,452 DEBUG Cannot open AvgUninstall key SOFTWARE\AVG Secure Search (error: e0010013)
2014-03-02 11:00:17,452 DEBUG Cannot open AvgUninstall key SOFTWARE\AVG Security Toolbar (error: e0010013)
2014-03-02 11:00:17,452 DEBUG Cannot open AvgUninstall key Software\Microsoft\Exchange\v8.0\Setup (error: e0010013)
2014-03-02 11:00:17,452 DEBUG Cannot open AvgUninstall key Software\Microsoft\ExchangeServer\v14\Setup (error: e0010013)
2014-03-02 11:00:17,452 WARN aCIZsGeLaCYauXzmqjW4XebGhpkyN84wX
2014-03-02 11:00:17,484 DEBUG Disabling IDP Self Protection has failed with error 0xe0010054
2014-03-02 11:00:17,484 INFO Attempting to uninstall AVG Identity Protection.
2014-03-02 11:00:17,484 INFO Attempting to uninstall AVG IG toolbar.
2014-03-02 11:00:17,484 INFO AVG IG toolbar not present in the system
2014-03-02 11:00:17,484 INFO Attempting to uninstall AVG Visionize toolbar.
2014-03-02 11:00:17,484 INFO (Google) toolbar not present in the system
2014-03-02 11:00:17,484 INFO (Yahoo) toolbar not present in the system
2014-03-02 11:00:17,484 INFO Attempting to remove MSI Data.
2014-03-02 11:00:17,484 DEBUG No product code found for our upgrade codes, nothing to do here
2014-03-02 11:00:17,484 INFO Attempting to remove Exchange server plugins.
2014-03-02 11:00:17,484 INFO Removing AvgOutlook addin
2014-03-02 11:00:17,484 DEBUG RootKey Software\Microsoft\Office\Outlook\Addins found, remove key avgoutlook.Addin (forced:1)
2014-03-02 11:00:17,484 DEBUG Failed to delete key 'avgoutlook.Addin': 0xe001003d
2014-03-02 11:00:17,484 DEBUG RootKey (null) found, remove key avgoutlook.Addin (forced:1)
2014-03-02 11:00:17,484 DEBUG RootKey (null) found, remove key avgoutlook.Addin.1 (forced:1)
2014-03-02 11:00:17,484 DEBUG Failed to delete key 'avgoutlook.Addin.1': 0xe001003d
2014-03-02 11:00:17,484 DEBUG RootKey (null) found, remove key CLSID\{9F39046C-801E-4E15-8CD9-ACF0ACF29048} (forced:1)
2014-03-02 11:00:17,484 DEBUG Failed to delete key 'CLSID\{9F39046C-801E-4E15-8CD9-ACF0ACF29048}': 0xe001003d
2014-03-02 11:00:17,484 DEBUG RootKey (null) found, remove key CLSID\{F083C5AB-08AD-4ABF-A2BE-8FA5C7D2F10A} (forced:1)
2014-03-02 11:00:17,484 DEBUG Failed to delete key 'CLSID\{F083C5AB-08AD-4ABF-A2BE-8FA5C7D2F10A}': 0xe001003d
2014-03-02 11:00:17,484 DEBUG RootKey (null) found, remove key AppID\avgoutlook.DLL (forced:1)
2014-03-02 11:00:17,484 DEBUG Failed to delete key 'AppID\avgoutlook.DLL': 0xe001003d
2014-03-02 11:00:17,484 INFO Removing Sharepoint plugin if exists
2014-03-02 11:00:17,484 DEBUG RootKey (null) found, remove key CLSID\{8B39AD4E-1AB3-4AE1-B533-706F1CACED83} (forced:1)
2014-03-02 11:00:17,484 DEBUG Failed to delete key 'CLSID\{8B39AD4E-1AB3-4AE1-B533-706F1CACED83}': 0xe001003d
2014-03-02 11:00:17,484 DEBUG RootKey (null) found, remove key CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82} (forced:1)
2014-03-02 11:00:17,484 DEBUG Failed to delete key 'CLSID\{6E801D47-45B7-4D10-8268-DBBD5C233F82}': 0xe001003d
2014-03-02 11:00:17,484 DEBUG Failed to open key 'Software\Microsoft\Shared Tools\Web Server Extensions\AVScanner': 0xe0010013
2014-03-02 11:00:17,484 INFO Removing Antispam plugin for Exchange 2000/2003 if exists
2014-03-02 11:00:17,484 INFO Exchange 2007/2010 not instaled on this machine
2014-03-02 11:00:17,484 INFO Attempting to remove NDIS driver.
2014-03-02 11:00:17,484 DEBUG Extracting avgremoverndis?.exe from .cab archive
2014-03-02 11:00:17,546 INFO FW removing policy
2014-03-02 11:00:17,858 INFO FW NDIS driver not present
2014-03-02 11:00:17,858 INFO Attempting to remove AVG from WSC.
2014-03-02 11:00:17,858 INFO unregistering from WSC
2014-03-02 11:00:17,874 INFO COM API WINDOWS SECURITY CENTER
2014-03-02 11:00:17,874 INFO WSC object created
2014-03-02 11:00:17,874 INFO WSC object attached
2014-03-02 11:00:17,952 INFO WSC object registered
2014-03-02 11:00:17,983 INFO WSC object unregistered
2014-03-02 11:00:17,983 INFO Begin of EnableWinFW.
2014-03-02 11:00:17,998 ERROR Turning WinFW on/off failed: 0x800706D9
2014-03-02 11:00:17,998 INFO End of EnableWinFW: 0x800706D9
2014-03-02 11:00:17,998 INFO Attempting to remove AVG services.
2014-03-02 11:00:17,998 INFO Processing service avg8emc, it can take several minutes...
2014-03-02 11:00:17,998 INFO Processing service avg8wd, it can take several minutes...
2014-03-02 11:00:18,014 INFO Service avg8wd is not installed
2014-03-02 11:00:18,014 DEBUG Service avg8wd RegCleanup
2014-03-02 11:00:18,014 DEBUG Registry keys for service avg8wd are not present
2014-03-02 11:00:18,014 INFO Processing service AvgMfx86, it can take several minutes...
2014-03-02 11:00:18,014 INFO Processing service avg9wd, it can take several minutes...
2014-03-02 11:00:17,998 INFO Processing service avgfws8, it can take several minutes...
2014-03-02 11:00:18,014 INFO Processing service AvgWfpA, it can take several minutes...
2014-03-02 11:00:17,998 INFO Processing service AvgWFPx, it can take several minutes...
2014-03-02 11:00:18,014 INFO Service AvgWFPx is not installed
2014-03-02 11:00:18,014 DEBUG Service AvgWFPx RegCleanup
2014-03-02 11:00:18,014 DEBUG Registry keys for service AvgWFPx are not present
2014-03-02 11:00:18,014 INFO Processing service AVGIDSDriverxpx, it can take several minutes...
2014-03-02 11:00:18,030 INFO Processing service AvgWFPa, it can take several minutes...
2014-03-02 11:00:18,030 INFO Processing service AvgLdx86, it can take several minutes...
2014-03-02 11:00:18,030 INFO Processing service AvgTdiX, it can take several minutes...
2014-03-02 11:00:18,030 INFO Processing service AvgWfpX, it can take several minutes...
2014-03-02 11:00:18,030 INFO Processing service AvgRkx86, it can take several minutes...
2014-03-02 11:00:18,030 INFO Processing service avg9emc, it can take several minutes...
2014-03-02 11:00:18,014 INFO Service avg8emc is not installed
2014-03-02 11:00:18,045 DEBUG Service avg8emc RegCleanup
2014-03-02 11:00:18,045 DEBUG Registry keys for service avg8emc are not present
2014-03-02 11:00:18,045 INFO Processing service avgfws, it can take several minutes...
2014-03-02 11:00:18,045 INFO Processing service AVGIDSWatcher, it can take several minutes...
2014-03-02 11:00:18,014 INFO Service AvgMfx86 is not installed
2014-03-02 11:00:18,014 INFO Processing service AvgRkx64, it can take several minutes...
2014-03-02 11:00:18,045 INFO Service avgfws is not installed
2014-03-02 11:00:18,045 DEBUG Service avgfws RegCleanup
2014-03-02 11:00:18,045 DEBUG Registry keys for service avgfws are not present
2014-03-02 11:00:18,014 INFO Processing service avgfws9, it can take several minutes...
2014-03-02 11:00:18,045 INFO Processing service AVGIDSFiltervtx, it can take several minutes...
2014-03-02 11:00:18,061 INFO Processing service AVGIDSFiltervta, it can take several minutes...
2014-03-02 11:00:18,061 INFO Processing service AVGIDSShimw7x, it can take several minutes...
2014-03-02 11:00:18,061 INFO Processing service AVGIDSDriverw7x, it can take several minutes...
2014-03-02 11:00:18,061 INFO Processing service AVGIDSDriverw7a, it can take several minutes...
2014-03-02 11:00:18,061 INFO Processing service AVGIDSErHrvtx, it can take several minutes...
2014-03-02 11:00:18,030 INFO Service AvgLdx86 is not installed
2014-03-02 11:00:18,061 DEBUG Service AvgLdx86 RegCleanup
2014-03-02 11:00:18,061 DEBUG Registry keys for service AvgLdx86 are not present
2014-03-02 11:00:18,076 INFO Processing service avgwd, it can take several minutes...
2014-03-02 11:00:18,076 INFO Processing service ContentFilter, it can take several minutes...
2014-03-02 11:00:18,045 INFO Service AvgTdiX is not installed
2014-03-02 11:00:18,076 DEBUG Service AvgTdiX RegCleanup
2014-03-02 11:00:18,076 DEBUG Registry keys for service AvgTdiX are not present
2014-03-02 11:00:18,045 INFO Service AvgWFPa is not installed
2014-03-02 11:00:18,076 DEBUG Service AvgWFPa RegCleanup
2014-03-02 11:00:18,076 DEBUG Registry keys for service AvgWFPa are not present
2014-03-02 11:00:18,045 INFO Service AvgRkx86 is not installed
2014-03-02 11:00:18,076 DEBUG Service AvgRkx86 RegCleanup
2014-03-02 11:00:18,076 DEBUG Registry keys for service AvgRkx86 are not present
2014-03-02 11:00:18,076 INFO Processing service AvgRemote, it can take several minutes...
2014-03-02 11:00:18,045 INFO Service AvgWfpX is not installed
2014-03-02 11:00:18,076 DEBUG Service AvgWfpX RegCleanup
2014-03-02 11:00:18,076 DEBUG Registry keys for service AvgWfpX are not present
2014-03-02 11:00:18,045 DEBUG Service AvgMfx86 RegCleanup
2014-03-02 11:00:18,076 DEBUG Registry keys for service AvgMfx86 are not present
2014-03-02 11:00:18,045 INFO Service avg9emc is not installed
2014-03-02 11:00:18,076 DEBUG Service avg9emc RegCleanup
2014-03-02 11:00:18,076 DEBUG Registry keys for service avg9emc are not present
2014-03-02 11:00:18,045 INFO Processing service AVGIDSFilterxpx, it can take several minutes...
2014-03-02 11:00:18,092 INFO Service AVGIDSFilterxpx is not installed
2014-03-02 11:00:18,092 DEBUG Service AVGIDSFilterxpx RegCleanup
2014-03-02 11:00:18,092 DEBUG Registry keys for service AVGIDSFilterxpx are not present
2014-03-02 11:00:18,045 INFO Processing service AVGIDSDrivervtx, it can take several minutes...
2014-03-02 11:00:18,045 INFO Processing service AVGIDSDrivervta, it can take several minutes...
2014-03-02 11:00:18,045 INFO Processing service AVGIDSFilterw7x, it can take several minutes...
2014-03-02 11:00:18,045 INFO Processing service AVGIDSFilterw7a, it can take several minutes...
2014-03-02 11:00:18,045 INFO Processing service AVGIDSErHrxpx, it can take several minutes...
2014-03-02 11:00:18,045 INFO Processing service AVGIDSErHrvta, it can take several minutes...
2014-03-02 11:00:18,045 INFO Service AVGIDSWatcher is not installed
2014-03-02 11:00:18,108 DEBUG Service AVGIDSWatcher RegCleanup
2014-03-02 11:00:18,108 DEBUG Registry keys for service AVGIDSWatcher are not present
2014-03-02 11:00:18,045 INFO Processing service AVGIDSErHrw7a, it can take several minutes...
2014-03-02 11:00:18,045 INFO Service AvgRkx64 is not installed
2014-03-02 11:00:18,108 DEBUG Service AvgRkx64 RegCleanup
2014-03-02 11:00:18,108 DEBUG Registry keys for service AvgRkx64 are not present
2014-03-02 11:00:18,108 INFO Service AVGIDSErHrw7a is not installed
2014-03-02 11:00:18,108 DEBUG Service AVGIDSErHrw7a RegCleanup
2014-03-02 11:00:18,108 DEBUG Registry keys for service AVGIDSErHrw7a are not present
2014-03-02 11:00:18,061 INFO Service avgfws9 is not installed
2014-03-02 11:00:18,108 DEBUG Service avgfws9 RegCleanup
2014-03-02 11:00:18,014 INFO Processing service AVGIDSAgent, it can take several minutes...
2014-03-02 11:00:18,014 INFO Processing service AVGIDSShimxpx, it can take several minutes...
2014-03-02 11:00:18,061 INFO Service AVGIDSFiltervtx is not installed
2014-03-02 11:00:18,108 DEBUG Service AVGIDSFiltervtx RegCleanup
2014-03-02 11:00:18,123 DEBUG Registry keys for service AVGIDSFiltervtx are not present
2014-03-02 11:00:18,061 INFO Service AVGIDSFiltervta is not installed
2014-03-02 11:00:18,123 DEBUG Service AVGIDSFiltervta RegCleanup
2014-03-02 11:00:18,061 INFO Service AVGIDSShimw7x is not installed
2014-03-02 11:00:18,123 DEBUG Service AVGIDSShimw7x RegCleanup
2014-03-02 11:00:18,123 DEBUG Registry keys for service AVGIDSShimw7x are not present
2014-03-02 11:00:18,014 INFO Processing service AvgTdiA, it can take several minutes...
2014-03-02 11:00:18,061 INFO Service AVGIDSDriverw7x is not installed
2014-03-02 11:00:18,123 DEBUG Service AVGIDSDriverw7x RegCleanup
2014-03-02 11:00:18,123 DEBUG Registry keys for service AVGIDSDriverw7x are not present
2014-03-02 11:00:18,030 INFO Service AVGIDSDriverxpx is not installed
2014-03-02 11:00:18,123 DEBUG Service AVGIDSDriverxpx RegCleanup
2014-03-02 11:00:18,123 DEBUG Registry keys for service AVGIDSDriverxpx are not present
2014-03-02 11:00:18,061 INFO Processing service AVGIDSErHrw7x, it can take several minutes...
2014-03-02 11:00:18,061 INFO Service AVGIDSDriverw7a is not installed
2014-03-02 11:00:18,123 DEBUG Service AVGIDSDriverw7a RegCleanup
2014-03-02 11:00:18,123 DEBUG Registry keys for service AVGIDSDriverw7a are not present
2014-03-02 11:00:18,014 INFO Service avg9wd is not installed
2014-03-02 11:00:18,123 DEBUG Service avg9wd RegCleanup
2014-03-02 11:00:18,123 DEBUG Registry keys for service avg9wd are not present
2014-03-02 11:00:18,076 INFO Service AVGIDSErHrvtx is not installed
2014-03-02 11:00:18,139 DEBUG Service AVGIDSErHrvtx RegCleanup
2014-03-02 11:00:18,139 DEBUG Registry keys for service AVGIDSErHrvtx are not present
2014-03-02 11:00:18,014 INFO Service avgfws8 is not installed
2014-03-02 11:00:18,139 DEBUG Service avgfws8 RegCleanup
2014-03-02 11:00:18,139 DEBUG Registry keys for service avgfws8 are not present
2014-03-02 11:00:18,076 INFO Processing service AvgApiWrapper, it can take several minutes...
2014-03-02 11:00:18,076 INFO Service avgwd is not installed
2014-03-02 11:00:18,139 DEBUG Service avgwd RegCleanup
2014-03-02 11:00:18,139 DEBUG Registry keys for service avgwd are not present
2014-03-02 11:00:18,076 INFO Processing service XmppAuth, it can take several minutes...
2014-03-02 11:00:18,014 INFO Service AvgWfpA is not installed
2014-03-02 11:00:18,139 DEBUG Service AvgWfpA RegCleanup
2014-03-02 11:00:18,139 DEBUG Registry keys for service AvgWfpA are not present
2014-03-02 11:00:18,076 INFO Service ContentFilter is not installed
2014-03-02 11:00:18,139 DEBUG Service ContentFilter RegCleanup
2014-03-02 11:00:18,139 DEBUG Registry keys for service ContentFilter are not present
2014-03-02 11:00:18,092 INFO Processing service raserver, it can take several minutes...
2014-03-02 11:00:18,045 INFO Processing service AVGIDSShimvtx, it can take several minutes...
2014-03-02 11:00:18,092 INFO Service AvgRemote is not installed
2014-03-02 11:00:18,154 DEBUG Service AvgRemote RegCleanup
2014-03-02 11:00:18,154 DEBUG Registry keys for service AvgRemote are not present
2014-03-02 11:00:18,108 INFO Service AVGIDSDrivervta is not installed
2014-03-02 11:00:18,154 DEBUG Service AVGIDSDrivervta RegCleanup
2014-03-02 11:00:18,154 DEBUG Registry keys for service AVGIDSDrivervta are not present
2014-03-02 11:00:18,108 INFO Service AVGIDSFilterw7x is not installed
2014-03-02 11:00:18,154 DEBUG Service AVGIDSFilterw7x RegCleanup
2014-03-02 11:00:18,154 DEBUG Registry keys for service AVGIDSFilterw7x are not present
2014-03-02 11:00:18,108 INFO Service AVGIDSFilterw7a is not installed
2014-03-02 11:00:18,154 DEBUG Service AVGIDSFilterw7a RegCleanup
2014-03-02 11:00:18,154 DEBUG Registry keys for service AVGIDSFilterw7a are not present
2014-03-02 11:00:18,108 INFO Service AVGIDSErHrxpx is not installed
2014-03-02 11:00:18,154 DEBUG Service AVGIDSErHrxpx RegCleanup
2014-03-02 11:00:18,154 DEBUG Registry keys for service AVGIDSErHrxpx are not present
2014-03-02 11:00:18,108 INFO Service AVGIDSDrivervtx is not installed
2014-03-02 11:00:18,154 DEBUG Service AVGIDSDrivervtx RegCleanup
2014-03-02 11:00:18,154 DEBUG Registry keys for service AVGIDSDrivervtx are not present
2014-03-02 11:00:18,108 INFO Service AVGIDSErHrvta is not installed
2014-03-02 11:00:18,154 DEBUG Service AVGIDSErHrvta RegCleanup
2014-03-02 11:00:18,154 DEBUG Registry keys for service AVGIDSErHrvta are not present
2014-03-02 11:00:18,154 INFO Service raserver is not installed
2014-03-02 11:00:18,154 DEBUG Service raserver RegCleanup
2014-03-02 11:00:18,154 DEBUG Registry keys for service raserver are not present
2014-03-02 11:00:18,108 DEBUG Registry keys for service avgfws9 are not present
2014-03-02 11:00:18,108 INFO Service AVGIDSAgent is not installed
2014-03-02 11:00:18,154 DEBUG Service AVGIDSAgent RegCleanup
2014-03-02 11:00:18,154 DEBUG Registry keys for service AVGIDSAgent are not present
2014-03-02 11:00:18,014 INFO Processing service AvgLdx64, it can take several minutes...
2014-03-02 11:00:18,123 DEBUG Registry keys for service AVGIDSFiltervta are not present
2014-03-02 11:00:18,170 INFO Service AvgLdx64 is not installed
2014-03-02 11:00:18,170 DEBUG Service AvgLdx64 RegCleanup
2014-03-02 11:00:18,170 DEBUG Registry keys for service AvgLdx64 are not present
2014-03-02 11:00:18,123 INFO Service AvgTdiA is not installed
2014-03-02 11:00:18,170 DEBUG Service AvgTdiA RegCleanup
2014-03-02 11:00:18,170 DEBUG Registry keys for service AvgTdiA are not present
2014-03-02 11:00:18,123 INFO Service AVGIDSErHrw7x is not installed
2014-03-02 11:00:18,170 DEBUG Service AVGIDSErHrw7x RegCleanup
2014-03-02 11:00:18,170 DEBUG Registry keys for service AVGIDSErHrw7x are not present
2014-03-02 11:00:18,139 INFO Service AvgApiWrapper is not installed
2014-03-02 11:00:18,170 DEBUG Service AvgApiWrapper RegCleanup
2014-03-02 11:00:18,170 DEBUG Registry keys for service AvgApiWrapper are not present
2014-03-02 11:00:18,139 INFO Service XmppAuth is not installed
2014-03-02 11:00:18,170 DEBUG Service XmppAuth RegCleanup
2014-03-02 11:00:18,170 DEBUG Registry keys for service XmppAuth are not present
2014-03-02 11:00:18,014 INFO Processing service AvgMfx64, it can take several minutes...
2014-03-02 11:00:18,154 INFO Service AVGIDSShimvtx is not installed
2014-03-02 11:00:18,170 DEBUG Service AVGIDSShimvtx RegCleanup
2014-03-02 11:00:18,170 DEBUG Registry keys for service AVGIDSShimvtx are not present
2014-03-02 11:00:18,123 INFO Service AVGIDSShimxpx is not installed
2014-03-02 11:00:18,170 DEBUG Service AVGIDSShimxpx RegCleanup
2014-03-02 11:00:18,170 DEBUG Registry keys for service AVGIDSShimxpx are not present
2014-03-02 11:00:18,170 INFO Service AvgMfx64 is not installed
2014-03-02 11:00:18,186 DEBUG Service AvgMfx64 RegCleanup
2014-03-02 11:00:18,186 DEBUG Registry keys for service AvgMfx64 are not present
2014-03-02 11:00:18,186 INFO Attempting to remove AVG drivers.
2014-03-02 11:00:18,186 DEBUG Deleting driver 'avgfwd6a'...
2014-03-02 11:00:18,232 DEBUG Deleting driver 'avgfwd6x'...
2014-03-02 11:00:18,295 DEBUG Deleting driver 'avgfwda'...
2014-03-02 11:00:18,342 DEBUG Deleting driver 'avgfwdx'...
2014-03-02 11:00:18,404 DEBUG Deleting driver 'AVGIDSDriver'...
2014-03-02 11:00:18,466 DEBUG Deleting driver 'AVGIDSEH'...
2014-03-02 11:00:18,513 DEBUG Deleting driver 'AVGIDSHX'...
2014-03-02 11:00:18,576 DEBUG Deleting driver 'AVGIDSfilter'...
2014-03-02 11:00:18,638 DEBUG Deleting driver 'AVGIDSShim'...
2014-03-02 11:00:18,685 DEBUG Deleting driver 'avgldx64'...
2014-03-02 11:00:18,747 DEBUG Deleting driver 'avgldx86'...
2014-03-02 11:00:18,794 DEBUG Deleting driver 'avgmfx64'...
2014-03-02 11:00:18,856 DEBUG Deleting driver 'avgmfx86'...
2014-03-02 11:00:18,919 DEBUG Deleting driver 'avgrkx64'...
2014-03-02 11:00:18,966 DEBUG Deleting driver 'avgrkx86'...
2014-03-02 11:00:19,028 DEBUG Deleting driver 'avgtdia'...
2014-03-02 11:00:19,075 DEBUG Deleting driver 'avgtdix'...
2014-03-02 11:00:19,137 DEBUG Deleting driver 'avgwfpa'...
2014-03-02 11:00:19,184 DEBUG Deleting driver 'avgwfpx'...
2014-03-02 11:00:19,246 DEBUG Deleting driver 'avglogdrvx86'...
2014-03-02 11:00:19,293 DEBUG Deleting driver 'avglogdrvx64'...
2014-03-02 11:00:19,356 DEBUG Deleting driver 'avglogx'...
2014-03-02 11:00:19,402 DEBUG Deleting driver 'avgloga'...
2014-03-02 11:00:19,465 DEBUG Deleting driver 'avgrkx86UniversalDD'...
2014-03-02 11:00:19,512 DEBUG Deleting driver 'avgbootx'...
2014-03-02 11:00:19,574 DEBUG Deleting driver 'avgboota'...
2014-03-02 11:00:19,621 DEBUG Deleting driver 'avgdiska'...
2014-03-02 11:00:19,683 DEBUG Deleting driver 'avgdiskx'...
2014-03-02 11:00:19,730 INFO Attempting to remove AVG running processes.
2014-03-02 11:00:19,777 INFO Attempting to uninstall CloudCare.
2014-03-02 11:00:19,777 INFO CloudCare not instaled on this machine
