blastfemme
Hi, I'm new here. Actually, I'm new to posting at forums, period. I have searched and searched for the past week to hopefully find a solution to my problem, but haven't been able to find anything helpful, so I thought I'd try this route. While there are plenty of other forum postings about Vista (and Tungsten), I couldn't find a solution to my specific problem.
Here's my issue:
I bought a Tungtsen E2 Palmone a couple of years ago and it worked just fine with Windows XP. I didn't do anything major with it other than transfer information (contacts & calender) back and forth using HotSync. However, I recently purchased a new Acer computer with Windows Vista - Home Premium (64 X2 Dual Core Processor 4400+) with 1.75 GB RAM; System type: 32-bit Operating System. I knew the old installation CD wouldn't be compatible with Vista, so I downloaded PalmdesktopWin62.zip from the support page at Palmone.com which claims to be the driver to get my palm to work with Vista. My problem is that I can't seem to get Hot Sync to work properly. Hot Sync begins, but then gets interrupted by a prompt message "create a new account for this PC". If I click "cancel", it shuts down. If I click "yes", then it asks me to put in a password. I don't have a password, nor was I ever given one. I didn't need to use a password while using XP, and I certainly never assigned a password to my Palm.
I'm terribly frustrated by all this. If someone can please help me out, I would REALLY appreciate it!!!
Here's my issue:
