Unexpected Errors(Blank Screen)
InTrouble
File; \Boot\ BCD
Status:0xc00000e9
Info An Unexpected I\O error has occured
Ok I have tried everything I have got 3 different disk for restore
disk 1 of 1 and disk 1of2 and 2of 2 I tried all disk
Disk 1 of 1 will take me to the menu of pressing f8
I have tried all of the options in f8 ,but no luck all take me to a blank screen that just stays there ,And my disk 1 of 2 and 2of 2 cant even get to work
my specs are
Processor: AMD Phenom 9100 Quad core processor 1.80 GHz
RAM 4gb
System type 64-bit operating system
and its windows Vista
Please help me
I also went into f-10 trying different boot ways but no luck either
I really haven't messed around with bios ,cause I know nothing about computers to be messing with that
richc46
InTrouble
Will the easy BCD even work on computers that cant get to windows screen?
The only way I can get to the safe mode and the stuff that comes up when you press f-8
Is by using the disk I bought when I bought my computer,but Safe mode or system restore doesn't work it freezes up half way through the process.
when I try safe mode a list starts to run but freezes up on
\WINDOWS\system32\drivers\disk.sys is were it stops at every time
when I try system restore it just goes blank screen and nothing.If you need more information ask ,and i will try to explain. I have no clue how to work on computers.
richc46
I hoping that the BCD will work.
InTrouble
I dont think I can use that but I downloaded it anyway might need for later
I cant even get into windows screen to use it
But it gave me a link to try on the site you sent me to it is
Recovering the Windows Bootloader from the DVD - EasyBCD - NeoSmart Technologies Wiki but for some reason I cant even use my disk to reboot it it act like it wont even read the disk
I got 3 disk all of which I bought with my system
Disk 1 of 1
Disks 1 of 2 and 2 of 2
when i use disk 1 of 1 it brings me to a screen To reboot system restore and all the stuff you get when you press f-8, but it freezes or screen goes blank if I try them.
The only thing that happens if i use no disk is.
I power it up it comes to a screen that has Gateway and 2 options to press F-2 BIOS or f-10 boot menu then after that screen goes away I get the error.
If i use disk 1 of 1 and restart the computer it does the Gateway thing then it goes to
(Windows is loading Files) it loads all way up ,then its got loading screen with a little box with green bar going across for like 10 seconds after that it just goes blank nothing else happens.
When I use disk 1 of 2 or 2 of 2 it does nothing but takes me to error screen even if i boot from dvd/cd rom
richc46
Make and model of computer, please.
richc46
IF this works you will lose your stuff and you have to install SPs, updates etc.
Boot the computer and during boot quickly and many times hit f11
richc46
richc46
Those links are rather old, guess they are no longer active. Im trying everything that I know but running out of options.
If you know someone that has a Vista cd, you can borrow and validate with your product key.
InTrouble
Well I have the cds I bought the day I bought my computer,but they seems to not work Ill try and find someone that has set to see if it is my disk
InTrouble
The way mine is
1st boot device is set [cd/dvd 4m atapi dv]
2nd boot device [SATA:3m-wdc wd6400]
3rd boot device [usb:IOI icro drive]
4th boot device [Network:B02 D00 Yu]
That is very close to what mine looks like
I am trying to find more pictures of what else i see
richc46
its set correctly
InTrouble
Yeah I have 2 of the exact same computers both 9100e and I compard bios and all was same
I did find another HD which is a xp and put it in and it works fine now
You think my hd is shot ?
richc46
Thats a very good possiblity with no way to test in this situation.
