Solved update flash player
calmat
hello everyone
I cannot watch you tube videos because i need new version of flash player, but when
I try to download new version nothing happens. do i need to uninstall old version of flash player
before i can install new version. If so can anyone tell me the correct way to do this.
regards calmat
richc46
I just download the new version without a problem. If you are having a problem because you still have the old version, uninstall from the control panel, then download and use ccleaner to remove any of the remnants to try again.
If it is not caused because you have the old version, which I think may be the case, can you tell us in detail what has happened.
calmat
hello richc46
i have just uninstalled the old version of flash player, but i still cannot download the new version.
regards calmat
richc46
What happens when you try?
richc46
That is what you are suppose to get. It is telling you step by step what you can expect. When I did it, I got the same thing. Wait 30 to 60 seconds. The UAC will come on asking for permission to continue.
richc46
Brink
Staff member
mvp
Hello Calmat,
Since you are not getting the install pop-up message at the bottom of your browser (IE9 ??), then you may have ActiveX Filtering turned on causing it to be blocked if you're using Internet Explorer 9 (IE9).
You might also see if you may be able to download and install the standalone exe version of Flash Player at the bottom of the link below instead.
https://www.adobe.com/products/flashplayer/support/index.html
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
richc46
Follow the advice given to you by Brink, hopefully it will work, if it does not try the suggetions in the link that I have given you. Between Brinks and my advice, I am sure that you will be able to download in the near future.
calmat
hello richc46 and brinks
You are both BRILLIANT and you have solved my problem, I am so glad that I have
friends like you to help solve my problems. Thank you again.
regards calmat
Brink
Staff member
mvp
You're most welcome Calmat. I'm glad that we were able to help. :)
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
richc46
Everyone here enjoys helping others and look forward to comments like yours. You are very welcome.
