Vista Codec Pack - 32bit & 64bit Media Player Codecs
dmex
ɠɛɐǨ
With these packages installed you won't need to install any other codecs.
When dealing with codecs, more does not equal better.
Having the least amount on your system is the best configuration.
This is exactly what the Vista Codec Package does for you.
You will no longer be restricted to using a specific player on 32bit or 64bit.
Vista MediaPlayer and MediaCenter will be able to play all your files.
Updated: 1st-November-2008
Vista 32bit MediaPlayer & MediaCenter Codecs: (everyone needs this version)
http://www.majorgeeks.com/download.php?det=5326
Vista 64bit MediaPlayer & MediaCenter Codecs: (64bit users only, after installing the above)
http://www.majorgeeks.com/download.php?det=5535
64bit NOTE: Vista Ultimate 64bit uses the 32bit player as the system default. The X64 Components include icons to allow you to change the system's default player between the 32bit and 64bit Windows Media Player(s).​
One other aspect of Vista x64 Windows Media Player(s) needs to be mentioned. If you associate a particular filetype to open with WMP while the system default is set to use the 64bit player, that filetype will always open the 64bit player when doubleclicked. This occurs even if you change the system default back to using the 32bit player.​
Vista Codec Pack Tools & Extras
Quicktime Lite for Vista Codec Pack
|MG| QuickTime Lite for VCP 1.1.2 Final
The Vista Codec Package no longer includes any QuickTime components. VCP is fully capable of MOV and 3GP playback without any QuickTime software installed. This release of QuickTime Lite for VCP uses the original MSI installer from Apple to install a 'lite' version of QuickTime which will provide full browser support for viewing and downloading QuickTime files.​
Media Player Classic Home Cinema Player :cool:
http://mpc-hc.sourceforge.net/
Media Player Classic is an extremely light-weight media player for Windows. It looks just like the good-old Media Player v6.4, but has lots of nice extra features.
MPC has, for instance, a built in DVD player with real-time zoom, support for AVI subtitles, QuickTime and RealVideo support and lots more. (keys 2,4,6,8 for Video Zoom)
Definitely a great replacement for the huge and clumsy Microsoft Media Players.​
GSpot Codec Identifier
GSpot Download
GSpot is a codec identification utility - identifies which video and audio codec compression method is used on any file, whether the matching codec is installed, and more.​
dmex
ɠɛɐǨ
Audio output and Speaker setup (Vista)
For DVD settings and audio such as AC3 Dolby Digital 5.1 surround
Open the AC3filter configuration shortcut, in the upper left you will see, Output format -
the default setting is : AS IS (no change) ..... you may set it as you wish.
All other audio playback
Open the Audio decoder configuration shortcut, scroll the left window down to 'Mixer',
place a check in the 'Mixer' box, and in the right-hand window select you speaker setup in the drop down list
Then check the box for LFE if you have a subwoofer attached.
To use SPDIF output
Go into Vista's Control Panel and navigate Sound/SPDIF/Properties/Advanced/Exclusive Mode
(depending on your sound device, the above path may be a bit different but similar)
Then CHECK the box [x] for the following 2 items
'allow applications to take exclusive control of this device'
'give exclusive mode applications priority'
If you are experiencing choppy or stuttering sound
Go into Vista's Control Panel and open the Sound applet
Select your output device in the list that appears
NOTE: the default output device is commonly labeled Speakers
Right click on the device and from the context menu click Properties.
Click on the Enhancements TAB.
Then CHECK the box [x] for Disable all enhancements.
NOTES on certain types of playback
If Windows fails to playback DVD's install Media Player Classic.
Some AVI files will require you to use the shortcuts provided in the settings folder.
Some MOV, MPG, MPEG, MKV, TS, or M2TS files will require you to use the shortcuts.Look in the settings folder.
To playback ASF files in Media Player or Media Center change the file extension to ASX.
To playback VOB files in Media Player or Media Center change the file extension to MPG.
When using the above shortcuts, the installation default is always marked for easy return.
Thanks to Shark007 for making the Vista Codec Pack available for everyone.
Vista Codec Package Homepage
tanuj_chadha
Devil
Thanks for such a nice post. It really helps. :geek:
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
dmex
ɠɛɐǨ
Updated to 4.7.0 - Thanks to Johngalt
----Changelog----
x32 Codecs
- fix ffdshow.ax failed to register in v469
- offer QuickTime Lite for VCP separately
x64 Codecs
- update ffdshow
- minor revisions and updates
- fix audio in MKV containers
Jeet Chowdhury
Which Version I Use x64 or x86.
I Have Vista x64 SP1....
    AMD Athlon 6000+ x2
    ASUS M2N-MX SE
    2x 1 GB DDR2 - 800 MHz
    Palit AMD (ATI) Readon HD4870 GDDR5 With Stock Cooler
    Creative X-FI XtremeGamers Fatal1ty Series
    BenQ E2200HD
    1920x1080
    250 GB Western Digital SATA2
    Cooler Master 1000W
    Cooler Master
    Cooler Master
    Logitech G7 Gaming Mouse
    Logitech G1 Gaming Desktop
    8 Mbps BSNL Broadband
dmex
ɠɛɐǨ
Hi Jeet,
Vista x64 uses the 32bit Media Player by default so everyone needs the 32bit version regardless, If you want to use the 64bit Media Player just install both 32bit and 64bit packages then you can use the start-menu links to switch the default Media Player from 32bit to 64bit ;)
Steven
corzair
thankyou was getting confused, but i installed both on my x64 vista home premium
works very well so thanks again
    AMD Athlon 64 X2 6000
    4Gb
    Ati 3870
Benergy
I most of the time use the x64 media player.
Seems to me that its still impossible to play FLAC files on it.
Or am I mistaken?
    Intel Q6600
    Gigabyte GA-P35-DS4 (rev. 1.1)
    4 X 1Gb Team Xtreem Dark 800
    MSI RX2600XT
    Dell 2007WFP
    1680 x 1050
    3x SAMSUNG HD321KJ
    1x SAMSUNG HD501LJ
    Cooler Master 550W
    Antec p180
Benergy
Thanx for replying :)
Guess i'll have to wait a bit.:rolleyes:
    Intel Q6600
    MSI RX2600XT
    Dell 2007WFP
    1680 x 1050
    3x SAMSUNG HD321KJ
    1x SAMSUNG HD501LJ
    Cooler Master 550W
    Antec p180
Jeet Chowdhury
What Is FLAC. Media Center Showing Invalid Codec. But Windows Media Player Play All Well.....:)
Btw, What Is The Profit of x64 Player?
    AMD Athlon 6000+ x2
    ASUS M2N-MX SE
    BenQ E2200HD
    1920x1080
    Cooler Master 1000W
    Cooler Master
    Cooler Master
dmex
ɠɛɐǨ
Hey Jeet,
Check the weblink in my last post for information about FLAC, I also mentioned why it doesn't work well on 64bit media players like media center ;)
The number of benefits about using 64bit are too many for me to mention, checkout some results here
benefits of 64 bit - Google Search
Steven
Jeet Chowdhury
Thanks Bro...
    AMD Athlon 6000+ x2
    ASUS M2N-MX SE
    BenQ E2200HD
    1920x1080
    Cooler Master 1000W
    Cooler Master
    Cooler Master
skunksmash
im coming for cake
thanx steven........great info
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
Drubei
Thank you! Was looking around for something like this. Been using Combined Community Codec Pack for awhile but it was only 32bit. You the man dmex!
johngalt
Antidisestablishmentarianist
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
dmex
ɠɛɐǨ
Updated Vista Codec Pack links above...
32bit changes include but were not limited to:
- update ffdshow to rev. 2035
- update 10 of Gabest decoders
- add shortcuts for DVR-MS settings
- add several filetype recognitions to WMP11
64bit changes included but were not limited to:
- update 9 of Gabest decoders
- add shortcuts to toggle libavcodec version (audio related)
Jeet Chowdhury
Is There Any Update Patch For 4.70 To 4.71 Cause I Will Have To Download Full File, And It Will Better If They Offer Automatic Update. That Will Be Cool....
    AMD Athlon 6000+ x2
    ASUS M2N-MX SE
    BenQ E2200HD
    1920x1080
    Cooler Master 1000W
    Cooler Master
    Cooler Master
