Jody Thornton
Power User
I thought this might be of interest to those of you still running Vista, and enjoy doing so. Apparently, some modern versions of Firefox have been made to run on Vista using these methods, so it might be promising.
[WIP] Windows Vista Extended Kernel
To prevent user confusion, I strongly recommend disregarding the tutorials and contacting me directly instead about the extended kernel. The original post was removed as it was continuing to confuse users. There will be further discussion about the evolution of the extended kernel in the coming p...
msfn.org
Software compatible with Windows Vista Extended Kernel
Here, you will find a list of software compatible with Windows Vista, after installing the new extended kernel by Win32. As this project is very new, this list will remain quite short for the time being. List: BeamNG.Drive 0.16 and later Chromium versions 53-73 beta (later versions currently do n...
msfn.org
- Operating System
- Windows 8 Pro x64
- HP xw8600 Workstation
- Two Intel Xeon Core2 Quad 3.2 GHz Processors
- Proprietary
- 16 GB DDR2 800 MHz
- Graphics Card(s)
- nVidia Quadro FX 3800 PCI-E
- Realtek HD Audio
- Samsung SyncMaster 213T 21" 4x3 Flat Screen
- 1600x1200
- Two Seagate Cheetah 300 GB SAS Disks
- PSU
- Proprietary
- Case
- HP xw8600 Workstation Case
- Cooling
- Two CPU Fans and One Larger Cooling Fan
- Microsoft USB Optical Mouse
- PS/2 Keyboard
- 7 mbps
- Other Info
Storage Interface: Two LSI 3000 SAS Adapters
Browser: Waterfox G3.0.2 (based on Firefox ESR 78.6)
