Vista fail/crash
dhairumian
My laptop (Sony Vaio) recently got blue screen and shut off. Now when i try to turn it on it says "BOOTmgr is missing". I tried to insert the intallation DVD for vista and install the OS over but when i go through the steps and click install windows it shows the loading screen (spinning circle on the cursor) and wont load anything. I also tried to do system recovery but that doesnt work either.
Any help would be appreciated
richc46
dhairumian
i have tried that but i still get the error. I have also partitioned my hard drive a while ago, and now in the system recovery options it shows that i have only 10 GB on C drive, which i think is the reason that i can't do a clean install.
richc46
Do you have stuff to save?
richc46
dhairumian
i am booting from the dvd. When i click "install now" it loads a screen that says "please wait" and the mouse/cursor turns into a hourglass, and it stays like that for hours ...
richc46
If you are booting from the DVD, sounds like hardware. LIkely the hard drive.
