Vista folders pane showing 2 of every folder
Howie
The pic is fairly self-explanatory, but as you can see on the left hand side in the folders pane, there is 2 of nearly every folder. Any idea what I have done and how to rectify this?
Oops sorry it doesn't show up too well on here. It can be viewed at http://i38.tinypic.com/xp1mjq.jpg
Brink
Staff member
mvp
Hello Howie, and welcome to Vista Forums.
I believe it would be easier to create a new administrator account, then copy the contents of your old user account's C:\Users\(user-name) folders into the corresponding new accoun'ts C:\Users\(user-name) folders. If everything checks out ok, then you can delete the old user account while logged on to the new one.
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
Frostmourne
Banned
No you have grouped them by type. Click type in the column header and then untick the group option. You don't need another account.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Brink
Staff member
mvp
Hello Frostmourne,
I believe he is referring to having doubles of all the user folders instead of the way they are sorted. ;)
    Lumia 1520 phone
Frostmourne
Banned
Hello Frostmourne,
Might have missed that:o but they seem to be grouped - ?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Brink
Staff member
mvp
LOL, no problem. "Group by" it is. ;)
    Lumia 1520 phone
Frostmourne
Banned
Strange that blank files are showing up too. They might have been copied or redirected and somewhere something got confused.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Howie
Thanks for all your help guys. I am not near the computer concerned at the moment, but as soon as I am I will let you know how I went. Cheers :)
Howie
The deselcting of Group didn't work, there was still the double-up happening, but I was obviously tired the other day and only just realised that on the main part of the pic where you've got Hard Disk Drives (2), Devices with Removable Storage (2), Other (21), and Folders (11), that all the folders in the Folders group are also in the "Other" group. Would I be right in assuming that normally they would not show up in the "Other" group and have somehow been duplicated into that section or something? Can I remove them from the "Other" group and have them remain in the Folders group?
Brink
Staff member
mvp
    Lumia 1520 phone
