Vista Partition merging troubles... Can you help ??
Modus
30
Hello Everyone.
I am having trouble Merging two partitions on my Laptop.
I have Vista 32b Home premium with A 320GB HD
I have three partitions at present.
My first partition (21.9 GB) has Vista on it
My second (47.91 GB) partition has Ubuntu on it
and my third (38.9 Gb) partition is empty.
I want to merge my (38.9 GB) third and last partition into my first (212.9 GB) Vista partition.
But I am having trouble doing this because they a separated by my (47.91 GB) Ubuntu partition which is in the middle.
For example My disk now looks like this :
212.9 GB (Vista) | 47.91 GB (Ubuntu) | New Volume 38.09 GB (Logical Volume)
Does anyone know how I can now safely merge the last 38.09 GB partition into my main (First) Vista 212.9 GB partition ????
I hope I have explained my issue clearly enough.
I look forward to any help!
Cheers for now
Modus
    Core 2 Duo " GB
    3 GB
    ATI 3650 HD 256MB GPU
    17 IN
    Hitachi HTS543232L9A300
AstaLaVista
Lost in Cyberspace
Vista Pro
1,234
Location
Miami, Florida. USA
Acronis Dics Director should help do this.
Partition Magic is another good appy.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    WD Velociraptor 160GB
    Samsung Sata 750GB
    Maxtor External 160GB
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
2,456
Location
NY USA
Hello Everyone.
Cheers for now
Modus
Modus
There is a round about way of doing this using a 3rd party app. You can use Paragon disk suite to delete the empty partition, then move the center partition to the extreme right, then expand the left hand partition.
Hope this helps and let us know if yuou need help
ken
    Dell Inspiron E 1405
    2@2.0
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Modus
30
Hi AstaLaVista
Great name by the way...
thanks for the fast reply.
So it is possible for me to merge the two partions together then, all be it where they are positioned!
are any of them freeware? Also would I need to create a bootable disk?
Or would I be able to perform the functions inside Vista?
Also what would i need to do to merge the first and last partition??
    Core 2 Duo " GB
    3 GB
    17 IN
Modus
30
Hi Ken and Thnaks
Would I be able to do this inside windows??
    Core 2 Duo " GB
    3 GB
    17 IN
2,456
Location
NY USA
Hi Ken and Thnaks
Parigon is a windows app so you have to run it from within windows, but since it is making changes to the disk it has to re-boot during each phase ans when it does it will boot outside of windows to make the actual changes.
Make sure you have a back up just in case. I have done this 50+ times and have not had a single problem with it.
ken
    2@2.0
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
AstaLaVista
Lost in Cyberspace
Vista Pro
1,234
Location
Miami, Florida. USA
Have not use it to do that myself but I know they do it. I don't think they are freeware but they may have a trial version you can use.
    EVGA GTX260
    1680 x 1050
    Samsung Sata 750GB
    Logitech G7
    Logitech G15
Modus
30
#8
I have actually just remembered I do own A copy of Paragon Partition manager 9.0
So I will did it out and give it A whirl.
Ill post back how I get on
Modus
    Core 2 Duo " GB
    3 GB
    17 IN
2,456
Location
NY USA
#9
Modus
Let us know if you need help
ken
    2@2.0
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Modus
30
#10
Hi again.
still ineed of some help guys...
I have installed Paragon Partition Manager 9 Express and restarted my system.
But when I start PPM 9. and try to use any of the functions I am met with this error message:
"Sorry The wizard cannot continue. Wizard did not find partitions that can be redistributed".
"Depending on your system configurations and hardware some disks can be unavailable for the program".
there is an option to click on that opens more of a description. this says:
"Wizard could not find any adjacent partitions to work with on this hard drive. Note hard drive must contain a pair of partitions that are located next to each other (two Primary and /or two Logical to resize between".
I am new to this and I have read a few horror stories about completely loosing all data after perfoming disk aprtitioning operations, So I would appreciate any help on this please.
I am not sure what to do next??
Modus
    Core 2 Duo " GB
    3 GB
    17 IN
2,456
Location
NY USA
#11
Hi again.
Modus
Modus
can you take a snip of the disk management screen (use the snipping tool built in to vista)?
thanks'
ken
    2@2.0
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Modus
30
#12
Hi Ken
Here is the screen capture.
    Core 2 Duo " GB
    3 GB
    17 IN
2,456
Location
NY USA
#13
    2@2.0
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Modus
30
#14
Is that okay even though Ubuntu is on it, Ken?
    Core 2 Duo " GB
    3 GB
    17 IN
Modus
30
#15
mmm..
vista own Disk mangement tool does NOT give me the option to do this.
The only options that I can do are to Delete Volume, or HELP!!
    Core 2 Duo " GB
    3 GB
    17 IN
Modus
30
#16
Sorry just realised it is you ZigZag3143 who is helping me...
Sorry about that mate.
    Core 2 Duo " GB
    3 GB
    17 IN
2,456
Location
NY USA
#17
mmm..
what about using parigon for the disk letter?
    2@2.0
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Modus
30
#18
I still cannot use Paragon ZigZag3143.
Still giving the same error message
    Core 2 Duo " GB
    3 GB
    17 IN
2,456
Location
NY USA
#19
do yoou have an xp boot disk? or some linux flavor?
    2@2.0
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Modus
30
#20
Hi again ZigZag3143
I have been away for a little while because I have just been using GParted Live .iso after creating A bootable USB key.
I have successfully Managed to move the empty (38.08 GB) Partition next to my main (212 GB) Vista Partition and Give it the drive letter "A".
This means that the two Partitions I want to merge together are now next to each other. which is what i originally wanted...
But I still cannot use Paragon PPM 9 to merge them.
PPM 9 still gives me the same error message as earlier!
Also when I try to use Vista own Disk management tool. I now have more right click options, such as:
Open, Explore, Change letter and Paths, Shrink Volume, Delete Volume, properties and Help.
Also I was not sure what options I should use when I was using GParted Bootable.iso
becuase it was not very clear about how I can merge the two partitions together.
I did not want to attempt it until I was Sure what to do!
Can you give me any suggestions on how I can merge the first two patitions ogether now plz??
I have attached a scrren snip to show you how my HDD looks now!!
Modus
    Core 2 Duo " GB
    3 GB
    17 IN
