Vista start up problem
Hey guys,
Windows Vista won't start up anymore. Various problems occur during the start up that prevent it from starting up. It occurred around 3pm or 4pm today when i was just on the internet and talking with my friend on MSN and then BAM! BSOD! The PC rebooted itself and came back up, but then it began giving me a looping 'windows explorer.exe has stopped working' error. So I rebooted again.
I tried Last known good configuration and it didn't work. Gives me a flashing BSOD and the PC restarts itself. Attempts to boot into normal mode sometimes brings BSOD and sometimes just stays black before the circular Windows vista logo that should appear.
Safe mode works fine. I'm currently on safe mode at the moment. It works fine. I've tried Start Up repair using my Vista CD and nothing. It says no errors were found. I've tried Norton scan and nothing there.
Here are my specs:
OS: Vista Home Premium 64-bit
CPU: Intel Core 2 Duo E7400 2.8Ghz
RAM: 4GB (2x 2GB Sticks)
GPU: Nvidia GTX 260 896MB
DirectX: 10
HDD: 500GB Seagate 7200 RPM
Motherboard: GIGABYTE EP45-UD3R
BIOS: Award Modular BIOS v6.00PG
Sound: Onboard Realtek HD Sound
If you guys can get this fixed for me... that would be great... because I gotta print off a school project for tomorrow.
CT
go into c:\windows\minidump and zip the dump file *.dmp, and upload it to us using the attachment tool (shaped like a paperclip) in the reply form
thanks
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
CT
if its not in minidump you can search for *.dmp. there may not be a dmp file.
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Sorry for the late reply Ken. Had some people over.
Earlier, I decided to uninstall a program called 'Daemon Tools'. Did that and Windows booted up fine! No problems at all. Worked on it for about two hours. Brother played a game on it and when I attempted to play a game afterwards, whatcha know... BSOD. Restarted windows and another BSOD...
Here are the minidumps for those two recent BSOD's.
Since you have other people on your pc...
Go ahead and run a full virus scan and malware check (malwarebyes).
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
I debugged the second dump, it says the faulty module is ntkrnlmp.exe which is invoked by dwm.exe
The first dump's faulty module is win32k.sys, which was invoked by csrss.exe, isn't that a server program? Not sure.
I have yet to search what that program is or why it caused the system to dump, just thought I'd throw that out there really fast.
I'm lost as to why those would cause a crash. I would do a system virus scan. Also, in the start search menu, type this: mrt.exe then hit enter, do a 'full' scan then let it run, it will take awhile...
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
Both .exe's are system programs...
Nothing you would've installed lol
[EDIT] I seen you figured that out :)
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
lol well I am a bit more computer savvy than your average computer user. Just not with too many errors. Also, on those two dumps, one was MEMORY_MANAGEMENT and the other was BAD_POOL_HEADER. I'm sure you saw that, but I thought i'd point that out.
I closed out the debugger :( but I know the win32k.sys is a driver. I'm going to take a deeper look at it and see if I can find an answer. Give me a min.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
I'm uploading a batch file, please download it, save it to your desktop, unzip it then run it as 'Administrator'. This is done by right clicking the file and choosing the 'Run as administrator' option. Its going to save a log of all your currently running processes, I would like to see what is running in the background.
P.S. Have you ran SFC?
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
SFC is system file checker but this sounds like a driver issue. Win32.sys and csrss are important system files. Are all of your drivers updated?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Sounds good. I'm currently in safe mode though, just to tell you. And as for the batch file, can I run it while still scanning?
And what's SFC? =P
Hmm, you can't boot into normal desktop? I dont think safe mode results will be sufficient. SFC is system file checker. Iim going to upload a shortcut to SFC, it will scan, then save a log to the desktop. Please zip the text file it creates and post it. Thanks :)
Oh, I forgot, This shortcut HAS to be ran as 'Admin'
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
I did a quick google search and a MS forum points to software incompatibility.
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
