Vista Unable to see XP in LAN
beh007
Heres my problem.
I got a laptop with Vista Ultimate 32bit and a XP desktop
Both of my PC is connected to DSL-2640T Modem+Router
I change both my PC under MSHOME group.
My laptop using wireless connection & my desktop is on cable.
I have read some thread by installing a update on XP and reset in Vista but nothing happens
I hope you guys can help me out. Thx
roy69
47,65,65,6B
Have you created any shares on your laptop?
You are also looking at the wrong screen.
Just click on the network icon to show the networked pcs. When you click on it you should see something like this.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
beh007
Yes i did done shared folder with all my computers. However, it cannot see any pc in the network. Is like my laptop become invincible to all computer in the network. It cannot be seen and cannot see others.
Barman58
Staff member
Hi beh007,
You also need to create identical users on both machines and set passwords for both.
the other thing to check is permissions, on the vista machine you have to set both sharing and security permissions. hope this helps
    Windows 10 Pro 1709 Fall Creators Update (16299.192)
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    2 x 1920x1080 @50Hz
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB +1TB
    Wireless Logitec - MX Master + M570 Trackball
    Wireless Logitec MK710 + K400+
    37.8 MB Down 9.5 MB Up
    AMD
    Samsung 32" TV
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)AMDAMD
    NAS 4TB +1TB
beh007
Im sorry, i have done that and even uninstall my service pack 1and still no hope. I tried putting same name, same group. I remember it cannot be work is when i installed Acronis director suit to resize my partition and updates to sp1 in the very night then it started my laptop become invincible and unable to see others pc. The first day i install Vista it is visible and other pc can acess it.
atl530i
Go into the Ethernet controller on the XP computer, click on the TCP/IP properties, then go to the WINS tab and enable Netbios of TCP/IP if it is not already enabled.
Then set your shares. If the XP computer asks for a user name and p/w, it is usually what you use to log into your Vista computer.
    Home Brew
    Intel E7200
    Gigabyte EP45-UD3P
    Kingston 4GB DDR2-800
    ATi Radeon HD3870 PCIe
    Creative Labs Audigy 2
    Samsung SyncMaster 940BW
    Seagate 7200.10 SATAII 250GB x2 RAID 0
    Western Digital 640AAKS
    Antec Neo550
    Antec P180
    Zalman 9500
    Logitech S510 Combo
    Logitech S510 Combo
    Comcast @ 10Mb
Try renaming both PC's to workgroup. As vista is very particular about this. Vista prefers that you change the name to what is already named. See if that helps.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Everlong
To xor or not to xor
I'm having the same problem. Trying to connect an old XP laptop via Ethernet to my Vista machine. Set IP and stuff up and it says it's connected, but I can't do anything like can't even ping.
It worked instantly a couple of months ago on another XP machine, just connected them and it seemed to pick each other up instantly, but it's just not happening atm.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
A couple of things to check. First make sure the XP machine has the LLTD responder. Here is the site to download.
Network Map in Windows Vista does not display computers that are running Windows XP
Next; Firewall and firewall settings. Norton and CA are known to have issues with networking computers. I was using CA firewall and anti-virus and it was giving me fits so I switched. Now no problems. Make sure your firewall is allowing access to network. Make sure you have set files you want to share set to sharing.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
Everlong
Managed to get it working. Missed a firewall option that kept the laptop hidden in Zone Alarm, so changed that and can send files over to the Vista machine.
Though I was attempting it at 2am last night, so probably explains why ^^
    ASUS Xonar DX
    100Mbps
Glad to here you have it working. I too was up till 3:00 am doing a reformat on wifes computer. I know what you mean when working in the wee hours of the morning.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
