Vista Update Problem!!
Maha88
I can't get vista ultimate to update or defender, when I try it shows error 80246008 which means I have to start BITS service but when I do that then it shows error 1068 for which I didn't found a solution yet, so if someone knows anything how to solve this please tell me.
And this is 32-bit version of vista.
Brink
Staff member
mvp
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
UberVDub
Start -> Run -> type "services.msc". Make sure the Background Intelligent Transfer Service is started and set to Automatic. If Run is not in your Start menu type "run" in the search bar. To change a Service settings, right click on the service in question and select Properties. Off the top of my head I am not sure what services BITS is dependent on, so you might get a message that it could not start because another service is not running. You may need to start those parent services.
