Volume auto max ?
mrclub
Banned
I don't know why, but the volume level of my Acer Aspire 4937G auto max itself to 100. Even if I move it to 0, it still auto increase to 100.
And it seems that this is spoilt ? I can't control it.
Help !
    Acer Aspire 4937G
    nViDia GeForce G105M
Lottiemansion
You appear to have registerred your system as a Windows XP system, is that correct?
Have you just installed some driver updates from MS or the system provider?
iIOf so, go to device manager & "Roll back" the drivers for the keyboard &/ or sound system. OK?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
mrclub
Banned
I am using Vista actually...
I don't think I ever install any driver updates.
Maybe it is hardware issue ? Just now my laptop couldn't detect my battery charging at all. When it couldn't detect it, I could control the part (picture attached above, probably the sensor). However, once my laptop can detect the charging, the sensor don't work anymore
    Acer Aspire 4937G
Lottiemansion
Please provide the make, model & opperating system details, Vista home, premium & what service packs you have installed etc. etc.
As you can see from the included picture, if some one needed details on my system the information is readily to hand. So, a good idea would be to update the system specs in your profile to keep a record of the details.
    40 Meg
tanuj_chadha
Devil
Try to do a BIOS update and check if it is able to fix it.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
