Solved Why is CD ROM Drive Unavailable?
yapeen
I have a Toshiba Satellite with Vista32bit and the CD ROM drive is not working. It is called MAT****A DVD-RAM UJ-850S ATA Device.
(:eek:**** indicate profanity so please use your imagination--starts with 's', ends with 't')
In 'Device Manager' I get this message "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing (Code39). When I click "check for solutions" nothing is reported back to me and I can't find out what Code 39 means.
When I try to update the driver, I get this message "The best driver software for your device is already installed. Windows has determined the driver software for your device is up to date."
I've also run a ParetoLogic driver scan and it says the driver is okay and up to date.
System Information says Drive-Not Available and Status-Error.
Also the Network Adaptor 6TO4 Adaptor is in a state of error and System Information says "This device is not working properly because Windows cannot load the drivers required for this device."
I think the problem was caused when I reinstalled my printer using the disc. I reinstalled it then updated it online. The disc drive whirred into action when I clicked to update the driver, I remembered I hadn't removed the disc and promptly did so...I think that was my mistake.
But how can I fix it? Does anyone know? Please.
Regards
Yapeen
    XC3940-Toshiba Satellite A100/400 NB
    Intel zCore Duo processor T2350 1.86GH
    1GB (512+512MB) DDR2
    15.4" TruBrite Widescreen XGA
    120GB (5400rpm) SATA
    dial-up
zigzag3143
Banned
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
yapeen
Ken
Thank you so much. The PC Hell link has fixed it. I didn't uninstall the driver, just followed the other instructions.
I'm a complete computer novice so it's wonderful to have this solved so easily (in the end!)
Thanks again.
Yapeen
    dial-up
blue75
Banned
Google FTW :D I can google just about anything and with a little sifting come up with the solution ;)
    gateway
    intel quad
    8 gig
    nvidia
    realtek
    19' widescreen
    1440 x 900
    581 gb
    High speed Comcast cable
zigzag3143
Banned
yappen
Glad you are working. It was an easy one for a change<g>
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
yapeen
I have had this problem again i.e. the CD ROM drive not being recognized. This message appeared when a disc was inserted, "Windows Media Center cannot detect a video DVD in the DVD-ROM drive. Insert a video DVD into the drive."
The previous solution couldn't be applied (i.e. for Error Code 39) but after a process of elimination I found the cause of the problem.
It was a Windows update:
Update for Windows Mail Junk E-mail Filter [March 2012] (KB905866)
[FONT=&quot]After uninstalling the update and restarting the computer, the drive was working once more.
Hope this information saves other people a lot of bother.
Yapeen
[/FONT]
    dial-up
