Actually i think I found it....is this what you needed?:
Checking file system on C:
The type of the file system is NTFS.
Volume label is Vista64.
A disk check has been scheduled.
Windows will now check the disk.
Attribute record of type 0x80 and instance tag 0x3 is cross linked
starting at 0x2170265 for possibly 0x102 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x3
in file 0x6fea is already in use.
Deleting corrupt attribute record (128, "")
from file record segment 28650.
Attribute record of type 0x80 and instance tag 0x4 is cross linked
starting at 0x2170367 for possibly 0x63 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x4
in file 0xac44 is already in use.
from file record segment 44100.
starting at 0x21703d8 for possibly 0x76 clusters.
in file 0x11388 is already in use.
from file record segment 70536.
Attribute record of type 0x80 and instance tag 0x1 is cross linked
starting at 0x21703d4 for possibly 0x3 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x1
in file 0x1233c is already in use.
from file record segment 74556.
starting at 0x21703ca for possibly 0x2 clusters.
in file 0x13eaa is already in use.
from file record segment 81578.
starting at 0x21703d1 for possibly 0x3 clusters.
in file 0x16796 is already in use.
from file record segment 92054.
Attribute record of type 0x80 and instance tag 0x0 is cross linked
starting at 0x21703cc for possibly 0x5 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x0
in file 0x1a202 is already in use.
The attribute of type 0x80 and instance tag 0x0 in file 0x1a202
has allocated length of 0x186a000 instead of 0x224000.
Deleted corrupt attribute list entry
with type code 128 in file 107010.
Unable to locate attribute with instance tag 0x0 and segment
reference 0x12e00000000cb8a. The expected attribute type is 0x80.
from file record segment 52106.
reference 0x20c00000000cbfc. The expected attribute type is 0x80.
from file record segment 52220.
reference 0x1300000001a207. The expected attribute type is 0x80.
from file record segment 107015.
reference 0x1500000001a210. The expected attribute type is 0x80.
from file record segment 107024.
reference 0x1300000001a24b. The expected attribute type is 0x80.
from file record segment 107083.
reference 0x1300000001a269. The expected attribute type is 0x80.
from file record segment 107113.
reference 0x5a00000001a2a5. The expected attribute type is 0x80.
from file record segment 107173.
246912 file records processed. Deleting orphan file record segment 52106.
Deleting orphan file record segment 52220.
Deleting orphan file record segment 107015.
Deleting orphan file record segment 107024.
Deleting orphan file record segment 107083.
Deleting orphan file record segment 107113.
Deleting orphan file record segment 107173.
8006 large file records processed. 0 bad file records processed. 0 EA records processed. 33 reparse records processed. 309432 index entries processed. 0 unindexed files processed. 246912 security descriptors processed. Cleaning up 5580 unused index entries from index $SII of file 0x9.
Cleaning up 5580 unused index entries from index $SDH of file 0x9.
Cleaning up 5580 unused security descriptors.
Inserting data attribute into file 28650.
Inserting data attribute into file 44100.
Inserting data attribute into file 70536.
Inserting data attribute into file 74556.
Inserting data attribute into file 81578.
Inserting data attribute into file 92054.
Inserting data attribute into file 107010.
31268 data files processed. CHKDSK is verifying Usn Journal...
34479944 USN bytes processed. Usn Journal verification completed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
232935423 KB total disk space.
99097300 KB in 107887 files.
78516 KB in 31262 indexes.
0 KB in bad sectors.
362631 KB in use by the system.
65536 KB occupied by the log file.
133396976 KB available on disk.
4096 bytes in each allocation unit.
58233855 total allocation units on disk.
33349244 allocation units available on disk.
Internal Info:
80 c4 03 00 9f 1f 02 00 b5 f2 03 00 00 00 00 00 ................
17 6d 00 00 21 00 00 00 00 00 00 00 00 00 00 00 .m..!...........
30 c7 eb 76 00 00 00 00 50 23 1f ff 00 00 00 00 0..v....P#......
Windows has finished checking your disk.
Please wait while your computer restarts.
