Asus drw-2014l1t DVD not working
jtracey
I just got a new asus drw-2014l1t DVD writer (SATA) and installed it in to my Vista box. Windows did its found new hardware thing and then said there is an error installing new hardware. I have no drive for the DVD and the device manager shows that a driver is needed, even though windows used the cdrom.sys driver. I can't seem to find a driver and nothing I have tried seems to work. Anyone know how to fix this or has the driver?
yaxo
I had the same problem with that DVD, but got it to work. I had to use drivers for silicon sata and then it worked. BUT, I do not remember which version of the SATA drives I used, tried several versions before it worked and I think that the latest drivers did not work. Try to look att your MB's website for drivers
jtracey
Thanks for the answer, it did not work. I loaded another hard disk with XP and every issue I had went away. :(, guess I'll just keep trying and use my Xp for the day to day stuff.
encryptech
Hi jtracey!
im new to this forum....so hi to all of u guys....:D
i had this problem some time ago with my notebook. i managed to fix it with a small Registry patch. ill include the steps below...
1. go to Device manager by typing "devmgmt.msc" in the RUN command (WinKey+R) or by typing at the quick search in the start menu.
2. right click on the dvdrw device and select uninstall.
3. after it has uninstalled run the patch and click ok when it asks to add information to the registry
4. now go to the device manager and click "scan for hardware changes"
5. the OS should find the dvdrw as a new device and install successfully.
tell me either it works or not.... hope this can help ur problem...
  • cdrom.reg
  • readme.txt
    Intel Pentium IV 3.00Ghz
    MSI PM8PM-v
    3GB
    ASUS nVIDIA 9600GT 512MB DDR3
    INTERNAL 6 CH.
    Acer 22 Inch Widescreen display 1480x1050
    1480x1050
    40GB Seagate + 40GB MAxtor + 80GB Maxtor
    Coolermaster 580W
    OEM
    Liquid
    logitech g7 (Black)
    Logitech g15 Gaming Keyboard (2nd Edition)
    1Mbps
encryptech
your welcome. glad that it worked.
    MSI PM8PM-v
    3GB
    INTERNAL 6 CH.
    1480x1050
    Coolermaster 580W
    OEM
    Liquid
    logitech g7 (Black)
    1Mbps
mk-Ultra
Hello, I am having problems with this same drive. I actually got it like 3 or 4 months ago, couldnt get it to work, and got so frustrated with it that I stopped trying. So Im here trying again. To the point ->
Driver seems to be working, running on Vista Premium 32 bit.
Device does not recognize Discs inserted. No matter what Disc I put in it (blank/written/DVD/CD) it just wont recognize that there is a Disc in the drive. Not sure what the problem is, could this just be a bad unit? Please help me if you can think of a solution!
Smeeloodallas
I had the same problem and used the registry patch suggested above. Follow the steps and it worked like a charm.
Arty69
PLEASE HELP!!! My Asus DRW-2014L1T was installed, burned DVD-s with Nero, Windows Media Player... However in the device manager it was shown as some other device under "optical storage devices". Today I have got my hands on some Lightscribe DVD-s, so I decided to reinstall the divers. Then I have got the firmware 1.02 update, but the dos-like screen just flashed for a sec and disappeared. Now my DVD-ROM is not seen in BIOS, in windows sometimes it gets installed as a CD-ROM, sometimes (after uninstall) as a Floppy Drive, sometimes not seen at all... Windows does not see it as a DVD drive... I built this machine from scratch, PLEASE HELP!!!
P5E Asus mobo, Vista Ultimate 32bit, 2x2gb A-Data DDR2 800MHz, E6750 Dual Core 2.66GHz, Asus EAH3870 x2 1gb...
johngalt
Antidisestablishmentarianist
All of you people that have benefited from this post need to be giving ec some serious rep points....
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
alex.hillman
Hey you fix worked great for me thanks! I have been trying to solve this problem for a while now. I'm will to bet that my old drive will work again too... thanks!
kingarick
Encryptech,
Thank you Encryptech, you had the best solution so far I've found for an Asus (or other DVD for that matter) not burning correctly. I ran into the 'The attempt to burn a disc failed. An unkown error occured (4251).' error burning disc from iTunes. I tried a number of things without success before I discovered your fix.
Your registry procedure worked the first time I tried, then iTunes failed the very next time I tried to burn a disc. I went through your procedure again where it burned about 60 percent of the disc before failing again. I have no idea why your fix worked then my system found someway to bypass it to make my DVD not burn correctly again.
Encrptech, or anyone else have any suggestions where I can get my Asus drw-2014L14 DVD to burn disc correctly? :confused:
