RunDll32 IEDSCS32.DLL
Posts
10
Setting up personalized settings for:
RunDll32 IEDSCS32.DLL, BrandIE4 SIGNUP
I got the above message after I logged in to Windows.
The screen was black out and the above message shown at top left corner.
It happened after I upgrade the IE to IE8.
How to resolve?
MWRed
I'd rather be fishin
Vista Pro
Is this the first and only time you have seen it?
Does the browser work, and are you able to configure it the way you want( like favorites, search provider, etc.)?
What you see is the initial settings for IE being setup and adding links for Microsoft,Bing,and a homepage.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    Creative X-FI Xtreme Gamer
    AOC 22" Widescreen
    320GB
    2 front, 2 back,one side
    Logitech Wireless LX310
    Logitech Wireless
    18/2 cable
    Hewlett-Packard SR5019UK
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    Realtec ALC888 Audio
    17" LCD Monitor
    160 Gb Usable Hard Drive
Posts
10
The message was there and didn't go away. I cannot login. Only a black screen and the message.
I'm not aware the IE setup. After the IE upgrade, it told me to restart and I did.
MWRed
Vista Pro
Ahh....well, that's unexpected. This happens before you get to a login screen?
Everything else about this that I have read, leads to it starting up afterwards and nothing else. I wonder why it's not letting you get to login.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    AOC 22" Widescreen
    320GB
    Logitech Wireless
    18/2 cable
Can you at all get into safe mode?
I wondered MWRed if able to get into safe mode, maybe able to do sfc scan.
I thought, right or wrongly, that as it is dll files that are maybe the cause, trying to put the files back in order with sfc might work?
Don't know how you think?
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
#8
Hi sam,
As you have tried system restore, without any luck.
Still in safe mode I think trying sfc /scannow would be the next step.
See below:-
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
When the scan is finished if there are any errors then run it 3 times, restarting the computer each time.
As each time you run it, hopefully files will be repaired.
During the scans a log is produced, if errors have been found, please include the log in your next post.
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
MWRed
Vista Pro
#9
Excellent suggestion. It threw me off when he mentioned that it was keeping him from logging in
Thanks for the ideas, kesume.
everything ive found about it, it was doing that at startup and was fine. Its almost as if its unable to finish what its doing and is getting stuck.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    AOC 22" Widescreen
    320GB
    Logitech Wireless
    18/2 cable
#11
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's:
    Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Posts
10
#12
I tried the "Selective startup using system config", but the problem still occur.
I have to make it clear that my computer can be booted up. The message appear only after I chose a user and entered the password. When the message shown, the screen is black out. I can go to "Start Task Manager" by pressing Ctrl+Alt+Del. In the Windows Task Manager, I can start a New Task (like control.exe, cmd.exe). So, I think there is some user files were corrupted and cause the problem.
MWRed
Vista Pro
#13
I wonder if it'd be possible to figure out, it task manager, which process it is that is causing this, and kill it so you can at least get to the desktop and go from there.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    AOC 22" Widescreen
    320GB
    Logitech Wireless
    18/2 cable
#14
Hi sam,
I like you was hoping it was the answer, however it seems not.
It does as we have said previously looks like, data was corrupted in.during transition.
When you changed up to EI8, did you at all get any opportunity to look in Device Manager to see if any driver updates etc., were required?
Can you get into device manager, if so see if there are any small yellow warning signs, that would indicate that items need updating.
May have a bearing on untangling the 'corruption'.
Thank's
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
MWRed
Vista Pro
#15
Agreed, any info you can give may help, no matter how small the bit of info is.
We won't give up, and i'll be curious to find out what may be causing this problem.
    AMD Phenom2 XII 560
    Biostar A780L3L
    4GB DDR3-1333
    xfx 9800 GT
    AOC 22" Widescreen
    320GB
    Logitech Wireless
    18/2 cable
Posts
10
#16
In the Task Manager:
Personalized Settings Application is running
Following Processes are running:
csrss.exe
dwm.exe
explorer.exe
rundll32.dll
taskemg.exe
taskmgr.exe
winlogon.exe
I went into the Device Manager and expanded each item, don't see any yellow warning sign.
sam one thing I should have asked you is please what is the precise Model number, and Make of your computer.
This info could help us. Graphics, audio, ram etc,.
Thank's
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
ilikefree
New Zealand
Posts
2,882
#18
If you think it is in the user accounts make another user account.
If the problem goes away you were right.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
Posts
10
#19
Kesume,
Manufacturer: HP a6614f
Processor: AMD Phenom 9500 Quad-Core Processor 2.20 Ghz
Memory: 6.00 GB
System Type: 64-bits Operating System
Display adapter: NVIDIA GeForce 6150SE nForce 430
ilikefree,
I login with other user, they all get the same rundll32 error.
I even tried to create a new user, it got the same message.
    M2N68-LA (Narra)
    2.50GB
    nVidia GeForce
    17" LCD Monitor
