Slow hard drive access times, gets slower with time!
ssabripo
This is my 3rd fresh clean install, using both Vista x86 and x64, and all new hardware as well (new mobo, HD's, cpu, ram, etc):
symptom:
after a day of two of creating a user account, the HD access starts to become excruciatingly slow, and gets slower with time. When you use explorer and want to access the Hard drives, the system takes 3-7 seconds to open the folder. When browsing pictures, it takes 3-6 seconds to switch to the next, etc.
Creating a new user account solves the problem temporarily, until a day or two passes, and then the same thing starts to happen! :mad:
What I've tried so far:
- Disabled Indexing (windows Search service)
- Disabled Hard Drive Indexing
- Tried booting up as IDE, as well as AHCI
- Created new install with RAID0, and same issue.
System:
* e8400
* Asus P5Q-E with latest bios
* 2 x 320 WD 3200AAKS Sata drives, 1 x 250 WD 2500AAKS Sata drive
* Asus SATA DVDRW drive
* 4 GB Crucial Ballistix PC2-6400 (DDR2-800)
I've noticed this problem accelerates even more when using the "sleep" power mode. But even when disabling this, It still happens.
I've googled for over 2 weeks. I've done 3 fresh installs, I've replaced all the HW, and used 3 different copies of Vista Ultimate, with same results! :cry:
UPDATE: here is a video of the problem:
YouTube - Windows Vista Hard Drive performance issue
Fumz
Buggin
Instead of disabling indexing in the services menu, try setting it to manual. In your hard drive's property sheet, on the general tab, check 'index this drive for faster searching'. See how that works?
Btw, are there any other services you've disabled? That may be a problem. Vista is pretty good about services, unlike XP, and you really don't need to go disabling a bunch of them. Doing so may cause more problems than it's worth.
However, if you must, I would advise setting services you don't want to manual... just in case... and follow Viper's guide: http://www.blackviper.com/WinVista/servicecfg.htm
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary
    1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
ssabripo
I haven't touched any other services except "windows search". I just tried your suggestion, and still same issue :(
there is gotta be something I'm missing.
Fumz
Buggin
Have you made sure to install your chipset drivers?
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
ssabripo
which chipset drivers? are you talking about these:
* Intel(R) P45/ICH10R Chipset Software Installation Utility WHQL V9.0.0.1009 for Windows XP/Vista & 64bit XP/Vista.
or these:
* Marvell 88SE6111 SATA Controller Driver V1.2.0.57 for Windows XP/Vista & 64bit XP/Vista.
SLAiNTRAX
Tried disabling Superfetch and defragmenting your HDD with a good tool like O&O Defrag?
    Me
    AMD Athlon 64 X2 4200+ 2,2GHz
    MSI K9NU Neo-V
    2x1GB TwinMOS DDR667 el-cheapo ram
    XFX nVidia GeForce 7900GS 256MB
    Creative X-Fi XtremeGamer
    Samsung SyncMaster 920n
    2x500GB Samsung HD502IJ in RAID0
    1x500GB Samsung HD502IJ
    1x200GB Samsung SP2004C
    NorthQ 4001BX 400W
    Thermaltake Armor Jr.
    Stock
    Logitech MX518
    Microsoft Wireless Photo Keyboard
    16000kbps/720kbps (real speed 15200/740)
    Need an upgrade...
ssabripo
superfetch disabled, and did a quick defrag. Still no dice.
when opening Windows Explorer, the top status bar has a green bar that goes from left to right....in my case, when double clicking on a drive/folder, that bar moves very slowly to about 1/4 of the way (takes about 5-7 seconds now), and then quickly finishes (1-2 seconds), and then it opens the request.
In a fresh new account, it does that almost immediately, so you really don't even see the little green bar.
Fumz
Buggin
or these:
I mean the Intel chipset drivers. The Marvell reference must be a typo... Marvell is your lan ports and has nothing to do with SATA drives or drivers, which are included in the Intel chipset drivers.
Maybe it's a power setting? Go to Control Panel/Hardware and Sound/Power Options. Check the High Performance box and then click 'change plan settings'. Then click 'Advanced Power Settings' and expand the + by Hard Disk. Make sure the disk is set to power off never.
Btw, you don't want to disable superfetch.
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
SLAiNTRAX
Do you have any old hard drives connected to you PC now? If so disconnect them and see if helps. Do you hear any noises from the drives when accessing one of them? I heard it from my RAID0 array a few hours ago and it took about 5 seconds to open up my music folder.
Happened just now again. Just heard a loud spin up noise from my PC. Everything locked up. Need to take a look what this could be.
    Me
    MSI K9NU Neo-V
    NorthQ 4001BX 400W
    Stock
    Logitech MX518
    Need an upgrade...
ssabripo
yes, I did that.
ok...just put it to never, and still the same. It was set to 20 min.
re-enabled.
ssabripo
I do...but that's not the problem. I've just replaced these drives (the previous drives exhibited similar behavior, so I thought it was a drive issue, thus got them replaced).
also, if it was a drive issue, it would happen consistently to all users. The problem is that it happens on the account after a day or two. If I goto another account, specially a brand new one I create, it works perfectly.
something is happening where Vista starts to store something somewhere in the account once it is left open for some time, and after it is put to sleep. Hell, even opening control panel takes forever. The entire system is at a crawl!!!
going to another account, like the guest or my wife's, works like it should...super fast.
Fumz
Buggin
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
Blaydrnnnr
Completely Lost
This is happening to all accounts you say? after some time? even your wifes and the guest account after some time? Not anything close to an expert here but could this have anything to do with restore? Ghosting an account or your drives?
    Q9550 2.83 Quad
    8 GB OCZ 800MHz
    Nvidia 9800 GT 1GB
    LG 24
    2 500 GB 32MB Seagate( Raid 0 )
    1 1000 GB 32MB Seagate
    PC P{ower and Cooler 1000W
    HP d5000t ATX CTO
ssabripo
yes...all accounts eventually. When a new one is created, it is fine. Then, after a couple of days, it starts to slow down....and eventually it is unbearable!
make a new one, and BAM, works great :cry:
bruce2
Vista Pro
Did you replace you SATA cable when you replaced your HD. How about wiggle and push the connection roughly in the way you shouldn't? Lol, that is how I got mine back to work with the same problem as yours. I like to add, you may try different SATA ports on the MB. After market cable works a bit better. Good luck.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
ssabripo
yes..believe me, I've changed the cables, the actual HD's, etc. I've tried even different mother boards (P5Q and P5Q-E) with same results. It is definitely not a hardware issue! this has something to do with a Vista setup or something.
is there any microsoft experts in Miami/Ft-laud that I can call?
NormCameron
This is a bit of a long shot, after 3 fresh installs, but check in the properties of the IDE channels to ensure the DMA Mode is enabled.
You could also check in BIOS. On the ASUS P5 Boards under IDE ou'll find a SATA mode - this should be Enhanced and SATA should be set to IDE - unless you installed Vista with it set to ACHI
    Scratch Built
    Intel Quad Core 6600
    Asus P5B
    4096 MB Xtreme-Dark 800mhz
    Samsung 206BW
    1680 X 1024
    550 w
    Thermaltake
    Targus
    Microsoft
    1500kbs
    Self built.
ssabripo
correct...I've checked the properties under device manager for the IDE, and it gives me either nothing, or set to Ultra DMA 5/6. For example, it shows ATA 0 set to UDMA5, and another ATA 0 set to nothing.
in Bios, I've set the SATA configuration to IDE, ENHANCED. I've also tried AHCI, as well as created a RAID array. In all 3 configurations, it behaves the same. That's why I believe it is a software issue, not a hardware issue.
