Taskbar acting weird
turkeypets
My Vista64 taskbar is acting strange out of the blue, i attached a couple pictures.
The time disappears and other icon shift to the right, and the middle of the taskbar turns black.
This happens once in a while. Advice would be very much appreciated.
    Vista64
Hi turkeypets:
Your images would suggest your having problems with the icons in your System Tray (i.e., at the far right of taskbar where the system clock normally appears). Is that correct?
I'm not sure why system tray icons like your system clock would occasionally appear/disappear, but right-click on a blank area of your taskbar and choose Properties (or go to Control Panel | Appearance and Personalization | Taskbar and Start Menu) and ensure the settings on the Taskbar and Notification tab are configured to your personal preference. Make sure all the standard Windows system tray icons you'd like to see (Clock, Volume, Network, Power) are enabled, and if you have other icons that load into your System Tray (e.g., icons for your antivirus, printer, etc.) that you always want to see then disable the "Hide Inactive Icons" checkbox.
Once your Quick Launch and System Tray icons are displayed on your taskbar the way you prefer go to the Taskbar tab and enable "Lock the Taskbar" and then see if that solves your problem.
    32-bit Vista SP2 Home Premium
    HP Pavilion dv6835ca
    Quanta 30D2 (U2E1)
    3 GB RAM
    NVIDIA GeForce 8400M GS
    64-bit Win 10 Pro v22H2
    Dell Inspiron 15 5584
    Intel i5-8265U @1.60/1.80 GHz
    Dell Inc. 07R8NW
    8 GB DDR4 SDRAM
Just restart.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
Hi turkeypets:
thanks Imacri!
i have all those setiings set already but this problem happens sometimes anyway. My volume sometimes dissapears too and dont work until i restart. My folder settings change by itself too. much more frequently than the taskbar problem. like Vistaar suggests to restart that does fix the taskbar, would love to know why it happens in the first place. i appreciate your time.
    Vista64
... My volume sometimes dissapears too and dont work until i restart. My folder settings change by itself too. much more frequently than the taskbar problem....
Hi turkeypets:
Your system tray icons look quite different than mine, but that might be because I have a 32-bit Vista SP2 Home Premium OS that is fully patched to end of extended support (11-Apr-2017).
What is the make and model of your computer, what edition of 64-bit Vista (Basic, Home Premium, etc.) do you have, and is Service Pack 2 (SP2) installed? If you aren't sure if your OS is patched to end of support launch your Internet Explorer 9 browser and go to Help | About Internet Explorer; if Windows Update delivered the final batch of Patch Tuesday updates on 11-Apr-2017 you should have Update Version 9.0.6 / (KB4014661) (Cumulative Security Update for Internet Explorer 9: April 11, 2017).
If you haven't done so lately, you should run a thorough Check Disk (chkdsk /r) and System File Checker (sfc /scannow) from an elevated command prompt with Administrator rights as instructed in my 18-Aug-2020 post in ChrisKouz's thread Rundll32.exe is Not a Valid Win32 Application / Vista Home Premium with SP2 to see if those built-in utilities can detect and automatically repair any problems with your system files. Once System File Checker has run to completion it should report "Windows Resource Protection did not find any integrity violations" as shown below. [Note: it is safe to run a thorough Check Disk if your hard drive is a HDD (i.e., a spinning magnetic platter) but I would skip this step if you have a SSD (solid state drive)].
    Quanta 30D2 (U2E1)
    3 GB RAM
    Dell Inc. 07R8NW
    8 GB DDR4 SDRAM
The reason his taskbar doesn't look like either mine or that of Imacri is because he's using a different theme (looks like Windows Classic). It also looks like he's got a low resolution system. However, the recommended fixes from Imacri seem to be appropriate to get the system to stop periodically screwing up.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
...like Vistaar suggests to restart that does fix the taskbar, would love to know why it happens in the first place.
Vista system tray icons have always been glitchy, and System File Checker was never known to solve this issue. You should probably consider a newer version of Windows.
    Intel Q6600
    3 GB
Hi turkeypets:
Have you made any progress with your taskbar icon issue?
If you still require assistance let us know if you're using a custom theme for your Windows installation other than "Windows Vista" (see Brink's tutorial at How to Change the Desktop Theme in Vista) and whether you've seen any other odd glitches with your Vista installation like unexpected changes in screen resolution, problems waking from sleep mode, etc.
If you suspect you might be having problems with your graphics card or other hardware component it would be helpful if you could publish a Speccy snapshot so we know your basic hardware configuration and current graphics driver. To publish a Speccy snapshot:
  1. Install Piriform's free Speccy utility (available for download <here>).
  2. Launch the program and allow it to populate the interface with information about your system software and hardware.
  3. Go to File | Publish Snapshot and copy and paste the URL this generates (e.g., http: // speccy.piriform.com/results/xxx... as shown in the image below) in your next reply.
** Note that I prefer to use the portable (spsetup132.zip) version of Speccy available <here>. I can unzip and run the .exe file (Speccy.exe for a 32-bit OS; Speccy64.exe for your 64-bit OS) from any location, including a removable USB thumb drive.
    Quanta 30D2 (U2E1)
    3 GB RAM
    Dell Inc. 07R8NW
    8 GB DDR4 SDRAM
