Vista boot problem.
Jlnwlf
My Vista Home Premium will not boot up. There is a clicking sound coming from my PC just before the boot is complete. After a few mins if trying to complete the process, I get a message to use the boot disk. I do not have this. How can I fix this issue and boot up my OS? Where can I get a boot disk? I can not get into Safe Mode.
Thanks.
    Vista Home Premium
wither 3
Where does the boot actually fail? For instance, does it say it's loading Windows?
Before getting into how to create a boot disc, did it ever boot previously? If so, can you get into Safe Mode?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
SIW2
Just use the vista installation disc. It has the standard MS repair options in it.
The clicking might be a concern, though not necessarily - some hard disks are quite noisy even when working normally.
Thanks.
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
Jlnwlf
The boot fails just before completing. I get the Microsoft icon and the loading bar scrolls left to right. It stays on this screen for a while then the clicking starts and it goes to a blank screen with a large mouse icon. I can move the mouse on the screen. It will automatically attempt another reboot, same issue but I get the error message to use a boot disk. I can not pull up safe mode.
    Vista Home Premium
Jlnwlf
I don’t have the installation disk. Can I get one from Microsoft or HP?
    Vista Home Premium
wither 3
I agree but, he didn't answer all my questions. If he can get into Safe Mode and run a sytem restore, it might not be necessary. On the other hand, having the ISO is good for the future.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Vistaar
...it goes to a blank screen with a large mouse icon...I can not pull up safe mode.
What antivirus programs are installed? “Black screen with cursor” was sometimes caused by AV conflicts: typically by having Microsoft Security Essentials and Avast installed at the same time. There is no good reason to have a legacy version of MSE installed on Vista or XP now because definition updates can no longer be installed. (MSE versions merely 6 years old or newer wouldn’t work anyway.) However I doubt that would prevent you from using Safe Mode, as you have twice stated.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
SIW2
MSE works fine on my vista installation. As Vistaar pointed out, probably not wise to use a 3rd party av and mse at the same time.
I would suggest use either mse OR a 3rd party av.
You can use mse version 4.4.304
In case it is needed
64 bit
mse4.4.304x64.zip
32 bit
mse4.4.304x86.zip
Then manually download and install the update for sha2 signing. (KB4474419) That is because the mse definitions are now sha2 signed.
64 bit:
32 bit:
When you have done that, mse is able to download and install the definitions. The same definitions are used on win7, and apparently MS will continue to provide them till 2023.
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
SIW2
Works fine:
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
Vistaar
You can use mse version 4.4.304....Then manually download and install the update for sha2 signing.
I regret opening the door for such extensive discussion of MSE when we don’t even know what antivirus OP has installed, but I consider using MSE 4.4.304.0 (released in 2013) to be a rather bad suggestion. Even before MSE definition updates became sha2 only, it was found that 2019 definition updates intended for version 4.10.209.0 didn’t work properly with that old XP-era version. (You might want to test at AMTSO to see if it can consistently detect and quarantine the EICAR test file.) In any case, most Vista users who post here (including the gurus) are never going to install any Server 2008 updates, and will therefore never have the sha2 support needed to test your suggestion. If someone running Vista wanted a free antivirus, I could only suggest Avast 18.8 (or AVG 18.8, which is essentially the same thing).
    Intel Q6600
    3 GB
Jlnwlf
I did answer your question. My last sentence was “ I can not pull up safe mode”. I tried to boot again today and got the same error message. Boot failed. Insert system disk and press enter. How much memory will I need for the Vista download. Can I boot from a USB drive or will I have to make a disk? The only internet connection I have is thru my iPad. Might be difficult to get a CD burned.
    Vista Home Premium
wither 3
Apologies for the oversight on my part. :o
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
