Solved WinVista HomePremium-X86 (SP1) Reinstallation Question
skeezix
Last week I downloaded a 2.9 GB file named "WinVista_HomePremium-X86(SP1)[.ISO].iso)" from archive.org. Here is a link to what I downloaded (Windows Vista Home Premium with Service Pack 1 x86 : Microsoft : Free Download, Borrow, and Streaming : Internet Archive just in case the link doesn't work for you). The file was uploaded by "shermanzuki" in February of 2018. It is pretty far down (8 or 9 screens) in the list of files.
I burned the file on a DVD and verified it as part of the burn. It verified okay. Then put the DVD away for future use. However, I'm not sure if I should have put something else on the DVD when I burned it. Would you happen to know what that might be? I've spent an hour searching around for it but can't seem to find it.
    Windows Vista SP2 32-bit Home Premium
    HP a6400f
    3 GB
    Integrated
    Samsung 27-inch
    500 GB Internal
    Not connected
skeezix
More...
The app that I thought might be needed in order for the Vista ISO DVD to reload Vista can be found here.
    HP a6400f
    3 GB
    Integrated
    Samsung 27-inch
    500 GB Internal
    Not connected
Joadix100
Active Member
i never burned a CD or DVD with an OS, however i did it with USB thumbdrive and i had to use RUFUS that basically "unzips" the ISO and puts it in the USB, i dont know but i think you had to "unzip" the iso with winrar or something else and then burn the contents in the DVD, maybe im wrong but maybe im not
If you burnt the .iso onto the DVD and not simply copied the iso to the dvd, the DVD now has a fully operational setup of vista
    Windows Vista SP2 x64 (with Extended Kernel)
    Acer Aspire 5315
    Intel Core 2 Duo T7700
    Acer Arcadia
    3GB DDR2 SODIMM 667MHz (1+2GB)
    Intel 965 Express Chipset Family
    Realtek ALC268
    AU Optrionics B154EW02 V7
    Somnambulist 120GB SSD
    Liteon PA-1650-02
    Integrated
    Qwerty US
    Trust Primo Black
    802.11g
    https://valid.x86.fr/x5di9k
    Windows 11 Home
    Me
    Intel Core i7-11700
    Asus Prime B560 Plus
    Kingston Fury 32GB DDR4 3200MHz (2x16GB)
    Nvidia GTX 1660Ti
    Vantec UGT-S220 7.1
    Comstar SY190HV
    Crucial BX500 SSD SATA3 1TB
    WD Blue WD10JPVX 1TB
    Toshiba HDWD110 1TBx2
    Cougar XTC500
    Thermaltake V100
    Corsair H55
    Redragon Griffin M607
    Redragon Mitra K551RGB-1-SP
    1Gbps
    https://www.asus.com/Motherboards-Components/Motherboards/PRIME/PRIME-B560-PLUS/
wither 3
I still suggest checking with S1W2 to see if he'll give you the .iso which has all the updates up to the EOL. No sense in having an SP1 disc.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
skeezix
Who is S1W2? If I can obtain an ISO copy of Vista Home Premium x86 with SP2 I'll burn that (providing that it works with my original Product Code, that is.
    HP a6400f
    3 GB
    Integrated
    Samsung 27-inch
    500 GB Internal
    Not connected
wither 3
I don't see my post where I provided a link to a thread (can't find it again) where you could have asked S1W2 for the appropriate ISO. I PM'd him a few minutes ago to see if he can help you out.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
skeezix
Thank you for your help. I did find S1W2 elsewhere in the long (168 pages and counting) thread in this forum. After reading through the various posts my mind just turned to mush. "Mind overload!"
    HP a6400f
    3 GB
    Integrated
    Samsung 27-inch
    500 GB Internal
    Not connected
wither 3
I haven't heard from S1W2. I have all the Vista update files but they're for x64.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
lmacri
Vista Pro
Hi skeezix:
I don't believe that SIW2 is still hosting their "full" slipstreamed Vista SP2 ISO (i.e., with SP1 + SP2 + all ~ 220 security updates released prior to end of support on 11-Apr-2017) on their MEGA archive. Ex_Brit hasn't been active in this forum since Dec 2021 but if you send them a private message they might still be able to provide their "regular" slipstreamed Vista SP2 ISO (with SP1 + SP2).
If you've already reinstalled Vista SP1 and re-activated your license (see the slui.exe 4 method in Step 2 / Option 2 of How to Activate Vista Normally and by Phone Activation) it might be easier for you to manually install Service Pack 2 and then use the Dism++ utility to patch Vista SP2 back to 11-Apr-2017. If you aren't familiar with Dism++ see SIW2's 02-Dec-2021 instructions in post # 3186 of Vista ISO Download. The GitHub home page for Dism++ is <here>.
Standalone .exe installers for 32-bit and 64-bit Service Pack 2 (KB948465, released May 2009) are still available for download from the Microsoft Update Catalog at https://www.catalog.update.microsoft.com/Search.aspx?q=Vista KB948465. See my post # 104 in Why SP1 May Not Be Available For You And How To Get It for more information about the SP1 and SP2 standalone .exe installers.
    32-bit Vista SP2 Home Premium
    HP Pavilion dv6835ca
    Quanta 30D2 (U2E1)
    3 GB RAM
    NVIDIA GeForce 8400M GS
    64-bit Win 10 Pro v22H2
    Dell Inspiron 15 5584
    Intel i5-8265U @1.60/1.80 GHz
    Dell Inc. 07R8NW
    8 GB DDR4 SDRAM
    Intel UHD Graphics 620
wither 3
I know Imacri know this but, just for clarification, the ISO from Ex_Brit doesn't have all the updates to the EOL.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Vistaar
No sense in reinstalling Vista at all really. There seems to be a presumption that skeezix would be better off running SP2 with oodles of security patches released in previous decades. Granted, some software would require SP2, and some would even require Platform Update (VLC comes to mind), but skeezix is evidently not using any such software. If we are concerned about his security, skeezix has made it clear that his Vista system is not connected to the internet, which suggests that he has better sense than some. That is a vastly better security precaution than patching Vista to April 2017 (or even January 2020). I do not share Imacri’s belief in the enduring value of old patches because Microsoft says otherwise. I also do not participate in discussions of custom ISOs because Microsoft holds exclusive rights to Windows Vista and has never relinquished redistribution rights AFAIK.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
skeezix
I'm thinking that my past problems have been due to a faulty contact in the cable between the power supply and the HD's power connector. After getting that fixed, everything is running fine, and I didn't need to reinstall Vista or anything else for that matter. The computer will remain out of the reach of the internet.
I did download the ISO version of Vista SP1 and created an installation DVD that appears to work on the Vista computer. I'm going to save that DVD in case the HD itself goes belly-up.
    HP a6400f
    3 GB
    Integrated
    Samsung 27-inch
    500 GB Internal
    Not connected
townsbg
~~тσωηsвg~~
I agree. Anymore it's hard to even install 7 on modern hardware. It's been almost 5 years since they stopped updating Vista and you can forget about driver support. I only run Vista on a Virtual machine now and I don't come here that often anymore. FYI you have to have a serial number to use vista.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
wither 3
I glad we were able to steer you in the correct direction in regards to the problem. Enjoy!
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
SIW2
Wither 3 can share his copy if he likes.
The good news is that I have just tested dism++ again and it is working better now. It can download and install all the updates to eol.
I suggest only installing 20 or so a time, then reboot.
Sometimes it fails to downlaod, so just click the blue Install Updates button again and it usually gets them on the second try.
I takes a little patience.
In case of difficulty, the whole package for x64 (64 bit)is here Dism++10.1.1002-Vx64.7z
In caseof difficulty, the whole package for x86 (32 bit) is here Dism++10.1.1002-Vx86.zip
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
SIW2
yes it will
you can search for 64 bit
en_windows_vista_sp2_x64_dvd_342267.iso
or for 32 bit
en_windows_vista_with_sp2_x86_dvd_342266.iso
    Vista
    Intel E8400
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
skeezix
Just to clarify and close this thread...
I keep my Vista computer running so I can use the program Corel Draw 12. I disconnected it from the internet and reinstalled Windows Vista SP1 (which did not require "activation", BTW). I then installed MS Word, MS Excel, an old version of Snagit, and the Corel program. I did not attempt to update Windows Vista to SP2 and I did NOT reconnect it to the internet. Now I am free from a multitude of problems that kept popping up when the computer was connected to the internet. I didn't have to buy and learn another, newer Draw program 'cause Version 12 works perfectly. I don't use that computer very much but when I do, it's a real lifesaver.
    HP a6400f
    3 GB
    Integrated
    Samsung 27-inch
    500 GB Internal
    Not connected
wither 3
Better late than ever. I know you want to close it out but I'm guessing the problems when the internet is connected occur because you don't have the Windows Updater set to never check for updates. However, since it does what you want, don't fix it.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
